Old 07-27-2007, 12:23 AM   #1
garthbf's Avatar
1975 31' Sovereign
1960 26' Overlander
Mount Vernon , Washington
my new project - '60 Overlander
I now have a new (old) 1960 Overlander. It is in rough shape and I still have to get it home. Background on this is in this thread, http://www.airforums.com/forums/f48/one-i-wish-i-had-26940.html
I will be updating this thread as thing go along. I plan on getting this home and doing a full restore on it. I will need the floor replaced and I plan on putting a gray water tank under the floor, I am thinking that the body will be coming off the frame.
Currently there is no title for it, it was lost. It was registered in Calf. but since it has not be tagged for many years they have purged it from there records. I am going to be able to get it titled in Wash. state with not to much hassle and get a 3 year conditional title.
I have some questions that maybe someone can answer
1. What is the ball size for this trailer?
2. What is the front wire plug on this trailer? The wires come from the TV pigtail and split and some wires go under the trailer and some go into the plug that is on the curb side of the front. How does this plug come out?
3. Where can I get a battery that fits the box on the front?
Garth
ID:	42021   Click image for larger version
ID:	42023   Click image for larger version
garthbf is offline   Reply With Quote
Old 07-27-2007, 08:00 AM   #2
dudebb's Avatar
1962 16' Bambi
Newtown Square , Pennsylvania
Hi Garth,
Nice looking Overlander. Good luck with the rehab. I would bet that the ball hitch is the same as our 62 Bambi at 2". The battery MAY be the same as well. I have printed off info supplied on the forum for an Interstate battery which is 19.25" long, 4.25" wide and 9.5" high. If that works for you it is model 3ET-VHD. List is $115.95 suggested Price is $99.95. You can check it out at Batteries for Everything Laptops, Camera, Phones, Cars, 2-Way Radio Battery, SLA, etc.. Can't help with the other question. Hope this helps.
George
1962 16' Bambi (sold )
1996 Buick Roadmaster Estate Wagon
Airforums# 7906, WBCCI #4248, WDCU
dudebb is offline   Reply With Quote
Old 07-27-2007, 09:02 AM   #3
Mel
Mel's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Hi Garth,
Great new project!! The ball size on our '60 is 2".
Good luck!
Mel
Mel is offline   Reply With Quote
Old 07-16-2008, 11:38 AM   #4
garthbf's Avatar
1975 31' Sovereign
1960 26' Overlander
update
Well it has been awhile since I update this thread. I got this home late last summer. I have not worked on it much since. Busy with other thing. It will need a full restore. I will have to replace all the wood on the inside. It is all rotten.
Here are some photos of when I got it home.
More to come later.
ID:	63801   Click image for larger version
Old 08-23-2008, 10:47 AM   #5
If I Rest I Rust
NatchezBear's Avatar
1960 26' Overlander
Natchez , Where the Old South Lives
What did you do with the plug and or pigtail on front panel ? It is 12 volt power supply as I have learned.I want to retrofit 12volt system to my TV.
NatchezBear
NatchezBear is offline   Reply With Quote
Old 08-25-2008, 09:55 AM   #6
garthbf's Avatar
1975 31' Sovereign
1960 26' Overlander
Is this plug that you are talking about? This is how it is right now and I have not changed it yet. The wires come off the pigtail from the TV and split off. some go into this plug on the front of the trailer and some go under the trailer.
Old 08-25-2008, 10:21 AM   #7
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Here's a close up of mine. I know the plug end goes into this receptacle and turns but without the male end of the cord, I just don't know which way it turns. This female receptacle is stamped with the following:
HART LOCK
15A - 125V
10A - 250V
A-H&H with the UL insignia
On the interior, almost directly behind this receptacle, there were two light blue wires coming out of the interior skin about 5 inches above the floor. I had been monkeyed around with by I don't know how many PO's because the two wires were hooked together with an in-line fuse and old black electrical tape. One of the wires went to the two overhead, original 12 volt lights in the ceiling, one in the galley area and the other in the bathroom. I wasn't able to trace the origin of the other one. Hope this helps.
FF
ID:	66211   Click image for larger version
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 08-25-2008, 10:40 AM   #8
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Upon closer inspection of your photo, it looks like your has a flip-up cover like the shore power hook-up connection. If that is the case, it is a Bargman 60-0-3 receptacle as pictured here. This connection point was usually located at the streetside rear for connection to shore power while at a campground. Have never seen one in the front but I guess all things are possible.
FF
Old 07-18-2012, 05:22 PM   #9
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
HART LOCK
15A - 125V
10A - 250V
FF
Brad this front female plug, do you have any idea what it is for? Working on a 59 traveler and it is there, no wires to it, no evidence it ever did. Does also have the Bargman shore power plug on the street side rear.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 07-18-2012, 06:14 PM   #10
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Yes, this plug that's on the curbside front curve is for a separate cord to the TV that only powered the 2 ceiling 12 volt lights. Mine is a "park" model which didn't have an on-board battery. I'll bet this '59 Traveler was without an on-board battery too.
FF
Old 07-18-2012, 07:25 PM   #11
goransons's Avatar
1963 22' Safari
Ahhh ok I get it. I'm guessing the same thing (noticing no dump valve either). There is a nice loop of wire inside the trailer in that approximate location. Would make a perfect location for a battery under the dinette seat. Thanks for the info!!
Scott & Megan
Old 07-18-2012, 07:40 PM   #12
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
That's where I put mine, mostly because of the ease of access from the entry door and because of these very wires.
Do your wires have a light blue insulation?
FF
