Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1958 - 1963 Overlander
Old 07-22-2008, 06:53 AM   #43
BarryIowa's Avatar
Profile:  1955 22' Flying Cloud
Polk City , Iowa
The good news is that there is a factory connection not far from the split so I will be able to take the entire line off from the fitting forward and have a new one made.
BarryIowa is offline   Reply With Quote
Old 07-22-2008, 07:21 AM   #44
thinking outside the box
Commercial Vendor
62overlander's Avatar
Profile:  1962 26' Overlander
1954 22' Safari
1954 22' Safari
Catonsville , Maryland
soapy water in a spray bottle... very important. Check every fitting when you put gas to it. I actually do it every time I go out, makes me feel safe about the propane. I will bet a buck once the gas line is fixed, your Dometic will fire right up. I love the fact that these 62 Internationals are totally functional on propane only. Do you still have the International furnace? Mine didn't fire up, but is was a rust bucket due to the salon windows leaking. Yeah, that is another spot to look into. Under the furnace....
The cool thing about these units is you get to learn a bunch of new skill sets in the process. Make sure to buy the tube bender as well as the flaring tool. Being able to make a bend without a kink is worth the small investment. I would also suggest you blow out the propane lines while you have the piece off. There was most likely water in the line and that caused the split. Disconnect the Humphrey's lamp and blow it out. It actually might be worth going from fixture to fixture. I know Tim Sheppard had some serious black goo come out of his lines when he did his 1960 Ambassador.
Post some more photos for us.
62overlander is offline   Reply With Quote
Old 07-22-2008, 01:18 PM   #45
BarryIowa's Avatar
Polk City , Iowa
LP Lines
Great advice. I will get the first and most obvious repair done but while the line is off I will blow out the lines, hook everything back up and check for leaks. I think the previous owner was under the impression that the fridge didn't work but I now think it was because the line was split.
Old 07-22-2008, 02:03 PM   #46
Commercial Vendor
1954 22' Safari
1954 22' Safari
Send me a PM with your mailing address and I will mail you copy of the instructions for cleaning, adjusting and caring for the burner stones and klixson tongue. The information was sent to me as a gift, so I feel compelled to share it. I also have an extra door tray if you need it. Frank
Old 07-26-2008, 07:15 PM   #47
BarryIowa's Avatar
Polk City , Iowa
A Bit of Progress
Okay, I'm on vacation in the Black Hills but I have free wifi so I thought I would give an update of some progress this week. I took the front door lock apart and took it to a locksmith so the Gerti could be locked while away. I also got the seals on the front and inner front doors - nice and tight. A bunch of parts came in so next in line for repair are the two roof vents. Then the new glass for the front picture window gets cut and installed. I'm hoping to have the new front wiring harness put in by the end of the weekend.
Question for you all. I was able to get one of the cam locks out. Does it make more sense to have a key made - the key is missing - or just buy new locks? Is originality a big deal on this sort of detail?
A big thanks goes out to Louis for helping me out with some parts this week!!!
Old 07-26-2008, 07:30 PM   #48
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Congrats on your progress. To me, it makes sense for all of your compartment door locks are all keyed the same. Keep a complete set of duplicate keys for everything on the trailer that another adult keeps in case one gets locked inside. Also include one of your TV on that key ring. Don't ask me why I think this is a good idea.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 07-26-2008, 07:35 PM   #49
robandzoe's Avatar
Profile:  1958 30' Sovereign of the Road
Plymouth , New York
Images: 26
I'm enjoying this thread
Barry,
I'm enjoying this thread as a bunch of my good Airstream buddies are particpants... check out my blog too, as the SOTR had a Shell On floor completed by GSM... and I documented with pictures when they did it and what they found.
Rob
Rob, Zoe', Stanton, Bryce and Braedon Baker
Past President WDCU
Do you Listen to the www.theVAP.com
Plymouth, NY 13832 WBCCI #2820
Courtesy parking
robandzoe is offline   Reply With Quote
Old 07-26-2008, 07:47 PM   #50
BarryIowa's Avatar
Polk City , Iowa
Blog
Hi Rob,
I look forward to reading your blog. I'm pretty sure that I'm going to replace the floors a half at a time. I don't want to start a restoration project that I plan to do well with a bad foundation. I'm going to camp in it a couple of times this year though to keep the family excited about it! I have no problem staying excited about aluminum. Brad says that I may have been infected with Aluminitus over the phone with him just prior to purchasing the camper.
Old 07-26-2008, 07:48 PM   #51
BarryIowa's Avatar
Polk City , Iowa
Brad,
I'm not sure I understand your comment about a TV key!?
Old 07-26-2008, 07:51 PM   #52
flyfshr's Avatar
Phoenix , Arizona
TV = tow vehicle.
FF
WBCCI/VAC #2699
Air #10
Old 07-26-2008, 08:31 PM   #53
Alumanutz's Avatar
Profile:  1966 22' Safari
Chico , California
I felt I was doing the right thing before, now I know!!
NUTZ
Alumanutz is offline   Reply With Quote
Old 07-27-2008, 12:22 AM   #54
Profile:  1963 26' Overlander
Great to hear of your progress, enjoy your vacation and keep the updates coming!
Old 07-31-2008, 05:11 PM   #55
BarryIowa's Avatar
Polk City , Iowa
Airstream Time
.....seems to move a bit slower than regular time. I started working on tackling the rear vent. Well, some of the parts are aluminum so I had to do some polishing. Then I figured I better paint the surrounding area because I had the lifters out of the way. Then I noticed that the item that looks like a giant transformer (I'm guessing to convert 12 volt to 110) looks like a fire hazard and also doesn't look original. Anyone have any ideas, please share. I'm including some of the pieces I polished and have ready to put back in place.
ID:	64822   Click image for larger version
Old 07-31-2008, 05:15 PM   #56
Commercial Vendor
1954 22' Safari
1954 22' Safari
put in a fantastic fan.... much more efficient.
New Restoration Project, '72 Overlander surferstyler 1972 Overlander 150 04-24-2009 03:29 PM
looking for other 1962 overlander owners 62overlander 1958 - 1963 Overlander 14 03-21-2009 05:44 PM
my new project - 60 Overlander garthbf 1958 - 1963 Overlander 7 08-25-2008 10:40 AM
1962 tradewind (project) - for sale p.dow For Sale & Wanted 2 06-29-2004 04:52 AM
Our '67 Overlander project robertandjenni General Interior Topics 16 05-14-2003 03:09 PM
