Old 07-14-2009, 08:45 PM   #1
1964 26' Overlander
Kearney , Missouri
Missing Rock Guard Extension Arm
My street side extension arm for the rock guard is missing. I have the base piece attached to the trailer it measures roughly 13 3/8" long. I believe the overall length of both arms is 25 1/2" long. Does anyone have a suggestion on where to obtain this?
Thanks.
64Overlander is offline   Reply With Quote
Old 07-14-2009, 09:01 PM   #2
1964 26' Overlander
Kearney , Missouri
Pictures of Rock Guard Telescoping Arm
Here are pictures of the rock guard arms. When I bought my airstream it had bolts holding the rock guard frame to the bracket attached to the trailer, is this standard operating equipment or is there another mechanism?
Thanks.
Name:	New window.jpg
ID:	83927   Click image for larger version
Name:	Rock guard Arm 1.jpg
Name:	Rock guard arm 4.jpg
ID:	83929   Click image for larger version
Old 07-18-2009, 09:15 AM   #3
campngirl's Avatar
1964 24' Tradewind
dousman , Wisconsin
Greetings,
RE: Extention arms
What you have for rockguard extention arms and brackets is the same as I have on my 64 Tradewind.... the one part missing also.
I have no idea what was originally used for a latch to hold that thing down... I am hoping that some other vintage owners will jump in and that we can both get an answer,,,,,,but maybe I can help a little with the extention arm issue.
Replacement extention arms with brackets that have spring knob latches
are available through most RV suppliers.... problem is the brackets that mount to the trailer skin are smaller, the mounting holes don't line up with the holes already in the skin from the original brackets.
--- You could patch the old holes in the skin using pan head rivets
and......use new arms and brackets and move them down and attach the to
the trailer to align with the lower edge or the guard
( there should be a hole on lower side frame ).... the free end of the
extention arms would attach to the guard side frame at about mid point
( where your bolt hold down was previously ). I have seen this configuration
on some older airstreams as well as how yours is set up currently.
---- or...... after patching the old mounting holes in the skin, you could try to move
the new brackets over alittle and still use the configuration that you currently
have ( The spring knob will latch into the hole where the bolt now resides ).
This may work as the new brackets are smaller.
---- If you want to use your original mounting brackets, just take the brackets off of the new extention arms and attach them to the old brackets. This will not solve your
problem with securing the rockguard in the closed position.
----- On newer units there are a latch or two along the bottom edge of the guard.
Hope ths helped a little.
Karol
campngirl is offline   Reply With Quote
Old 07-18-2009, 10:18 AM   #4
Distantdrummer's Avatar
1975 31' Sovereign
Houston , Texas
Sorry cannot help with info or availability of your missing part. Did the prev owner not know what had happened to the bracket? Maybe it's in his gaarage. I guess you checked all the compartments on the trailer??
But I am very glad to see this thread. I am interested in all things "rockguard".
I am hoping someone can chime in whether your exact type of rockguard was a stock item from the factory. Is there by chance any branding info on the frame at all?
The green horizontal corrugated fiberglass shield may not be original but the frame appears to be commercial made (not home crafted).
My trailer has the curved wing windows so a flat guard is not proper for my front, but I am always dreaming of a way to shutter all the windows (for storage) and this style has given me ideas.
If you ever get the opportunity I wish you could take a few more pics of the brackets and a shot that shows the hinge from the closed perspective. And a straight on shot with the guard closed showing front of trailer.
Was your trailer Ohio or California made?
Lastly what is that gadget attached front curbside below the extension arm ? Maybe an antenna holder?
thanks
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Old 07-18-2009, 12:23 PM   #5
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
Thanks.
Don't exactly know where Kearney, Mo is but if you are anywhere close to Colaw's trailer salvage in Carthage, you might check there. They are usually good for little parts like that. You might have to look the salvage trailers over pretty good to find it.
Jim and Sandy
"To know is nothing at all. To imagine, is everything." --Albert Einstein
https://chaosinature.blogspot.com/
Isadora is offline   Reply With Quote
Rock Guard Dieselgrin 1970 - 1973 Sovereign 2 11-14-2008 01:16 PM
Got a rock guard on! Isadora All Argosy Trailers 14 07-30-2008 04:55 PM
Missing support arm for 31' 76 sovereign chris's 67 Awnings 3 01-31-2008 05:48 AM
is a rock guard necessary? flyingcloud Rock Guards, Segment & Window Protectors 33 07-28-2005 03:28 AM
