Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1958 - 1963 Overlander
Old 08-17-2007, 05:11 PM   #1
62overlander
not the shiniest rivet
62overlander's Avatar
Profile:  1962 26' Overlander
Catonsville , Maryland
looking for other 1962 overlander owners
I just bought a 1962 Overlander to use as a family camper. I looked at every vintage trailer sales avenue for close to a year. I was seriously out bid too many times to be able to count, and that evil "buy it now" button was pushed by someone before I could get the basic questions asked time and time again until last saturday when I pushed the button... the "buy it now" button, at 6am. I took a get chance buying a trailer sight unseen. But low and behold... to my surprise the only thing that does not work is the furnace... The original dometic has made ice cubes(small ones but ice cube none the less) within 24 hours of lighting it up. I entered this purchase thinking that I would be repairing everything through out. Is it possible to find a 1962 Airstream that really only needs a refurbishment and not a total rehabilitation? So if anyone has a 1962 Overlander I would love to compare trailers to find out how some updates and such were made by you. First project: SEAL THE SHELL TOTALLY..
read my blog at: http://annalumanum.blogspot.com/ or view my photos at: http://picasaweb.google.com/dadofava1966/AnnaLumanum02
WBCCI, VAC, WDCU#7183
62overlander is online now   Reply With Quote
Old 08-17-2007, 06:09 PM   #2
LHall
LHall's Avatar
Profile:  1962 28' Ambassador
Phoenix , Arizona
1962 Ambassador
Welcome to the forums and congrats on your rig.
We purchased a 1962 Ambassador about a month ago. It is in great original condition, I have some pictures posted in my profile if you would like to see some of the configuration to see if it would help you.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
LHall is offline   Reply With Quote
Old 08-17-2007, 07:49 PM   #3
Overlander & Sea
Overlander & Sea's Avatar
Profile:  1961 26' Overlander
Gulfport , Mississippi
Welcome to the forums. Your Overlander looks great. We have a '61 Overlander that we purchased about 1 1/2 years ago. There are pictures of it on this site under the PO's name of 61overlander & the name darkstar (by mistake). I found the information here priceless. Good luck.
Rick, JJ, Tommy, and Will
1961 26' Overlander International Land Yacht
WBCCI #9275
"So, why do we drive on a parkway and park on a driveway?"
Overlander & Sea is offline   Reply With Quote
Old 08-18-2007, 09:53 AM   #4
62overlander
have either of you replaced your furnace? I have a ducted furnace and want to change it out without doing too many modifications. Any advise is apreciated.
Old 08-18-2007, 10:02 AM   #5
Overlander & Sea
No, I have not replaced my furnace. It does have the original one in it, and International Oil Burner, that does not work. I just replaced the AC with a Carrier Low Profile with heat strips.
WBCCI #9275
Old 07-15-2008, 05:22 AM   #6
62-Lander
Polk City , Iowa
62 Overlander
Hi there,
Our stories are similar. I just brought 62 Overlander International home Saturday and expected nothing to work. I am replacing the weather beaten 110 cord in the next few days and have started cleaning her up. I'm sure after reading your post that I will need to do more work than you. The floors are a bit spongy around the door so I'm sure they will need to be replaced there. The furnace and hot water heater had been replaced and the old Coleman air conditioner still blows cold air but I do need a new shroud for it. The vents both need to be replaced. My brother fabricated the front one out of Lexan and it is beautiful. Most everything works and it is all original with the original Zoletone paint inside and the wood was never painted. Let's stay in touch through out. You can look me up and check out my thread for pics.
Cheers,
62-Lander is offline   Reply With Quote
Old 07-15-2008, 07:44 AM   #7
LHall
LHall's Avatar
Phoenix , Arizona
Congrats on your AS. We have had ours for over a year already and have addressed many issues to feel safe in using our trailer. One of the first things we did was to replace the electrical cord and I recommend you do that first. We actually had a short to the skin of the trailer which you can imagine was quite electrifying! Welcome to the forums, you will find a ton of information on here that will be invaluable. As well, greetings from a former Iowan. I am originally from Leon.
Our trailer is similar and if we can help with information, let us know.
Take care,
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 07-15-2008, 08:41 AM   #8
utee94
Profile:  1963 26' Overlander
Originally Posted by 62-Lander View Post
Hi there,
Cheers,
62Lander-- 62Overlander is aka Frank, and you can check out his blog which is in his signature, and linked here:
Anna Lumanum
You can also look at his thread here on the Forums, linked below.
http://www.airforums.com/forums/f109...ack-37562.html
Between those two, you can see a lot of the things he has done while restoring/renovating his trailer. There's a lot of good information there, especially since it's the same year and model as your own. And he's a nice guy so I'm sure he wouldn't mind if you wanted to PM him or e-mail with some additional questions as well.
And obviously, your brother has a great deal of knowledge and will no doubt be a tremendous help to you. Looking forward to following your restoration, good luck!
Old 09-03-2008, 02:22 PM   #9
WithChild
Profile:  2006 16' International CCD
Minneapolis , Minnesota
I just purchased a '62 Overlander which has already been (mostly) restored. I'm really enjoying it and it has been a big hit around here. So far, I have had to have the water heater "re-built", and set off a couple roach bombs to get rid of little hitchhikers. I'm planning to install a new Carrier low profile AC next Spring.
I really bought the thing on impulse and am still a little stunned that I actually did it. Not that I'm regretting it, but I'm told that buying a vintage AS is a lifestyle decision. I also have a 16 ft. Quiksilver Edition Bambi. The two couldn't be more different.
I look forward to reading more from other Overlander adventurers!
WithChild is offline   Reply With Quote
Old 09-04-2008, 09:16 AM   #10
NatchezBear
If I Rest I Rust
NatchezBear's Avatar
Profile:  1960 26' Overlander
Natchez , Where the Old South Lives
My story is very close to yours. I expected the worse and was greatly surprised. My stance on this is ......good tires,bearings,axles,hitch and running lights......all else can be fixed over time. These ole girls are built well and are like a blank canvas that can be paint to your personal taste and preferences.The sky is the limit and the open road your buffet....... FEAST!
NatchezBear is offline   Reply With Quote
Old 09-05-2008, 05:47 PM   #11
LHall
LHall's Avatar
Phoenix , Arizona
Welcome
Welcome to the 1962 club! Ours is an Ambassador, esentially the same trailer just 2 feet longer. We have done quite a bit to ours, so feel free to let us know if we can help!
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
1966 Overlander International Double Tamara 1966 Overlander 30 03-28-2006 02:55 PM
Thinking of Buying '72 Overlander Joe C 1972 Overlander 16 07-20-2005 06:01 AM
1962 24' Oddball? Mark in Modesto 1959-69 Tradewind 10 12-24-2002 12:23 AM
PROUD NEW OWNERS of a 1974 International Overlander Anna Our Community 6 11-09-2002 07:29 PM
2-door Overlander InsideOut 1958 - 1963 Overlander 0 08-30-2002 08:14 AM
