Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1958 - 1963 Overlander
Old 07-27-2009, 07:29 AM   #673
Profile:  1963 26' Overlander
Thanks all.
And yes, more clamps will be absolutely necessary for the galley and front lounge renovations. There are going to be a lot more curves up there that will need to be clamped down.
I'm just so thrilled that JP pioneered this for us, and did such a great job documenting it. I must admit I was pretty intimidated by it at first, but it has turned out to be fairly straightforward (though certainly time-consuming) and it's also a lot of fun.
Old 07-27-2009, 09:59 AM   #674
Profile:  2008 25' Safari FB SE
Crawford , Colorado
I'm impressed. I've remodeled a couple of houses, but that's not cabinetwork and I know the difference. I did a rustic cabin and now a log house—that's the easy way to remodel. Cabinetwork takes skill, time and good luck and is a big step up from what I do.
Gene
CrawfordGene is offline   Reply With Quote
Old 07-27-2009, 10:11 AM   #675
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Excellent work Marcus. You just may have inspired me to do another trailer since my TradeWind is already road worthy. I really like the curves, always have. So where to next? What section of the interior is on the top of your list?
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 07-27-2009, 10:38 AM   #676
Thanks Gene, kind of you to say. I didn't really have any cabinetry experience before I started, I'm just learning as I go along. It's a lot of fun for me, I enjoy this type of thing since it's a major departure from my normal desk-job life. I've already learned some things I'll likely do differently on future cabinetry projects, nothing major, just simple things that will save time and produce a product that's easier to perform the detailed finish work upon.
Brad--
Good question, I need to organize this in my mind so I might as well do it here:
1) Next step is to pressurize and leak test the plumbing while I still have easy access to all of the lines and connections. before the cabinetry goes in for good.
2) Then I will complete and install the tall wardrobes, they are actually already veneered, I just need to edge-band the doors, install the corner moldings, paint the interiors, and figure out how I want to treat the two surfaces that face into the bathroom. I've considered aluminum panels, plexi panels, or simply sanding them down and painting them with water-resistant paint as they were originally. I still have some of the white urethane marine paint I used for the tub.
3) Veneer the upper lockers, repair the sliding door tracks, and install the new doors. Then, mount them.
4) Install the beds
Then, I'm done. Piece of cake, right?
Actually, there's still some finishing-up to do on the black tank valve (need to install the extender handle), and I need to install the gray tank valve as well, right now it doesn't have anything on the exit. But the major work to be done is for the inside, and it's coming along nicely.
I'd love for you to pick up another trailer and renovate it, your TradeWind is beautiful. I wish you'd been able to jump on that 56 (or 54?) Cruiser we saw advertised in New Mexico about this time last year, that looked like a fantastic restoration candidate. But no worries, there's always another one.
Old 07-27-2009, 11:09 AM   #677
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
hmmm... looks like a trip out to TX to have my interior done may be in order.. Will you start a new business Marcus?
Love it!
Marc
Old 07-27-2009, 12:31 PM   #678
Marc--
Ha! I'm flattered, but I'm just a hack.
As I'm sure you know, I refer all people interested in REAL cabinetry to Frank's Trailer Works in Baltimore, Maryland. His work is amazing, and I'm sure he'd be happy to build radius corners into whatever furniture you like.
Here's one example of his fabulous work, a vanity for a 61 Ambassador, fabricated in ropy cherry veneer:
I love that piece!
Old 07-27-2009, 12:39 PM   #679
Addicted to Aluminum
A-Merry-Can's Avatar
Profile:  1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
aww, shucks... I didn't pioneer anything! I just started cuttin and gluin'
One step ahead of ya, buddy! What are you looking at getting?
Jordan
8576 • • • • • • • •
there's always room for one more!
• • www.toolbox-design.com • •
A-Merry-Can is offline   Reply With Quote
Old 07-27-2009, 04:27 PM   #680
Okay, I'm on a roll now. I pulled the wardrobes out of the garage in order to paint the insides today. I would have been happy to leave them natural, but at some point they'd been painted in white latex by a previous owner. So I went ahead and painted them out in a soft, modern green color to match some of the colors I'll be using elsewhere (naturally I don't have any pictures of this).
But, since they were out of the garage, sitting in my driveway, right next to the Airstream... that's right, I just couldn't resist. I had to pull them inside and test-fit them.
This is more of the African ribbon-striped mahogany on the wardrobes. In fact, that's the whole reason I bought the mahogany veneer in the first place. I think they turned out pretty nice, and more importantly, my lovely wife is delighted with it. I think the ribbon stripes give the wardrobes a very tailored and sophisticated look.
They don't quite fit, most likely due to the slight change in floor height from the old 5/8" subfloor, to the new 3/4" subfloor. I'll have to trim down the bottoms a little bit, but that was expected.
Here's a panoramic shot from my iPhone. It's low-res of course, but I like the wide angle view:
I'm really happy with the way the woodworking is turning out. Now, back to work!
Old 07-27-2009, 05:21 PM   #681
Vintage Kin
REDNAX's Avatar
Profile:  Beaumont , Texas
I would imagine that goes double in your wife's estimation of the entire trailer project; IMO, there's nothing like it when she gets behind the whole project with fresh enthusiasm. We're to be selling our house in Corpus Christi (off to Beaumont where at least it rains), and the house needs some paint. Shade is key to everything down here on the Coastal Bend (what works in Florida, or what works in Mexico, works here not at all) only a quite pale one will do. Color is almost irrelevant by comparison. I love seeing her inspiration working with one of the color wheels we've worked with before. I hope that "tailored" look gives some of the same inspiration.
I really love the rounded corners. That's a requirement, now, for me! Only a question of radius!
(On an unrelated note, the thought of a trailer "sitting up" in swampy Beaumont has me thinking of adding a direct connection for exterior electrical that bypasses the trailer system. Possibly same for A/C, switchable. The de-humidifier would have to run continuously I was reminded as I admired the work you're doing.)
2004.0 DODGE 2500 Cummins 305/555; 6-manual, 7,400-lbs; 19 mpg city; 22-25 hwy; 13-15 towing. All miles at 1,700-1,900 rpm.
Sold: 1983 Silver Streak 3411 Supreme; 6,860# (8,000 GVWR)
Classified section, vintage kin
http://www.airstreamclassifieds.com/...p?product=6935
REDNAX is offline   Reply With Quote
Old 07-27-2009, 06:43 PM   #682
flyfshr's Avatar
Phoenix , Arizona
Jordan
I've been following your Liner thread. I have no idea what's going to present itself to me but it will need to be a 13 panel and hopefully a whaletail. A friend of mine is gifting me a '68 Overlander but I won't get it until the heat breaks around September.
FF
WBCCI/VAC #2699
Air #10
Old 07-27-2009, 07:15 PM   #683
FF
Really? Got any pictures of it? What kind of condition? There is a lot I like about those 66-68 trailers, especially the Internationals that had the mahogany interiors.
Hmmm, maybe that's why mine now has some mahogany on the interior too?
We looked at a 68 Overlander that my wife liked so much we almost bought it on the spot, but the seller was just asking way too much and wouldn't budge, so we had to pass on it.
Old 07-27-2009, 07:20 PM   #684
flyfshr's Avatar
Phoenix , Arizona
Nope, no pictures yet. Since it won't be until September, he's using it as storage for the time being. Pictures of a fully stuffed trailer don't interest me and the trailer is currently about an hour and a half north of here. I haven't seen this one in person just yet. Might need to do a road trip soon.
FF
WBCCI/VAC #2699
Air #10
Old 07-28-2009, 08:32 PM   #685
Thanks for the nice words, Rednax. I hope you're able to find a suitable replacement for your beautiful SS when you get to Beaumont.
Old 08-05-2009, 09:17 PM   #686
Finishing up work on the vanity right now. It still needed its bottom fold-out door, and the bottom to the upper cabinet. So here is the new lower door, with the original closing hardware.
Man I need to vacuum in there. And here it is with the door open.
This gives me some limited access to plumbing supply lines and drain lines. I can also place some shallow bins down here, with spare plumbing bits and other bathroom-related items.
But I wanted better access, so the shelves that form the bottom of the upper storage cabinet just slide in and rest on tabs all the way around. They can be removed via the finger-holes.
I slotted the one on the left, so it can be pulled in and out, while still allowing room for the drain line.
I also installed the door pulls, but my camera battery died before I could get pictures of that, so you fine folks will just have to wait until next time.
1966 Overlander International Double Tamara 1966 Overlander 30 03-28-2006 03:55 PM
Thinking of Buying '72 Overlander Joe C 1972 Overlander 16 07-20-2005 07:01 AM
73 Overlander for sale markdoane For Sale & Wanted 0 04-19-2004 08:28 AM
2-door Overlander InsideOut 1958 - 1963 Overlander 0 08-30-2002 09:14 AM
Charging AC on 71 overlander smily Furnaces, Heaters, Fireplaces & Air Conditioning 7 07-25-2002 06:33 PM
