Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1960 - 1964 Overlander
Old 01-22-2011, 02:19 PM   #81
Central , Mississippi
Kitchen mockup is pretty much done. That's a lot of small pieces of wood!
I may get some 5/8 ply and make a top just for kicks...
Time to move on to the next piece...
Name:	Kitchen Test Fit 2.jpg
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 02-05-2011, 05:05 PM   #82
Last night we had a light dusting of snow, but the sun was out so I decided to work on the exterior stuff today.
1st item of business was to tryout my new rivit remover to make the ceiling sheet metal managable. It is 2 pieces, each 4 ft wide and buck riveted down the middle...today it was to become 2 seperate pieces...the only tough part was dealing with all the latex paint...it was actually thick enough to clog the drill bit...I finally got the parts hung on the fence with some of the other pieces...
Then it was time to pull off the AC unit...it went much easier that I expected...actually a 1 man job if ya got the right stuff...30 year old ski rope is required...
the rest of the day was spent drilling out shell-to-c-channel rivets. I removed ALL of the wheel well rivets, then I used the fancy rivet driller to center drill each rivet head. The rivet tool tends to clog so then I used a standard drill bit to remove every other rivet in the floor c-channel. Slightly over 300 rivets drilled out today...120+ left to go before the Full Monty...
I really like the no-ac look
Name:	Big ceiling.jpg
ID:	121531   Click image for larger version
Name:	Rivit Drill.jpg
Name:	Split Cieling.jpg
ID:	121533   Click image for larger version
Name:	Off with the AC.jpg
ID:	121535   Click image for larger version
Old 02-06-2011, 04:35 AM   #83
Thats going to be a sweet interior. I love the fifties trailers with the rounded cabinets. Not so much in Airstreams, but in Spartan Manors and some others they were used extensively. It really adds character to the cabinetry.
I also didn't like the roof AC idea at all. I don't care if that's the only place an RV engineer can figure out where to put them, they're ugly and they look worse on an Airstream than on most white boxes. I installed a small window unit on a slide-out tray in my Safari and I'm really happy with the way it works. It's possible to get smaller units then they make for rooftop mounting also, so I sized one for my little trailer that's only about 18-1/2" wide and 15" tall and it works great. I can cool the interior on an 85-90 degree day parked in the sun, down to 64 degrees.
A few other cool things about it, I can run it on a single Honda 2ooo generator with power to spare, and I can replace it with a new one for $200 at Gnome Depot, or a used one for $50 off of Craigslist. Try that with a rooftop model. Oh, it has a remote control also, so I never have to get out of bed to mess with it.
Best to you,
Rich the Viking
VIKING is offline   Reply With Quote
Old 02-06-2011, 06:26 AM   #84
Ah, this all looks so familiar. Very nice work, keep it up!
Old 02-06-2011, 04:41 PM   #85
In one of the early posts I noted that the front flooring had been replaced but not done properly. Here is a photo of why it's so important to properly bolt the floor to the c channel...with the shell only slightly lifted...the c channel is free to slide right off the flooring!
Anyway...today Dolly got seperated...300+ rivits drilled...with some help from our sponsors! ...those 6 'hidden' rivets were an evil trick played by the factory
Name:	no stinkin bolts.jpg
ID:	121611   Click image for larger version
Name:	We have lift off.jpg
Old 02-06-2011, 07:02 PM   #86
Lothlorian's Avatar
Loganville , Georgia
Holy Cow! You have been really moving along on your trailer. Looks like you are doing a great job.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 02-06-2011, 07:25 PM   #87
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
Nice work Vernon. Some great tricks you have up your sleeve.
Lance
Lance M is offline   Reply With Quote
Old 02-06-2011, 08:42 PM   #88
nmbosa's Avatar
Nowhere , Washington
Congratulations! That is a big step. Keep up the good work.
Norm
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 02-11-2011, 05:46 PM   #89
Guess what happens in the morning...
Dolly's top is almost off...
All that is left is to disconnect the umbillical just below the floor and lift the front 4".
Name:	night time lift off.jpg
Old 02-12-2011, 12:25 PM   #90
NicheVintage's Avatar
1965 26' Overlander
Scottsdale , Southwest
Images: 34
What a great picture.
NicheVintage is offline   Reply With Quote
Old 02-12-2011, 02:41 PM   #91
Dolly looses her top
I guess this can be called 'productive'...
I finished the shell jacking this morning...hooked the Jeep to the floor...and drove away! I did stop by the garbage can and dispose of the last 8' of floor...exposing two passengers in the belly pan...
Anyone need these things? (last photo...)
ID:	122087   Click image for larger version
Name:	Holy Floor Batman.jpg
ID:	122089   Click image for larger version
Name:	Low shell.jpg
ID:	122091   Click image for larger version
Name:	store floor.jpg
Name:	Free stuff.jpg
Old 02-12-2011, 03:50 PM   #92
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Best to you,
Rich the Viking
how about a photo of how that is set up? I am looking to do the same on my 66. I saw one install that was pretty cool. Thanks
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 02-13-2011, 03:24 PM   #93
Busy weekend...This camper is one of the years that has the belly pan wrapped up, behind the exterior skin and rolled over the c-channel...I guess there is no way of pulling the belly pan without pulling the shell! The front pieces of ply came off real easy...no bolts into the c-channel...exposing the biggest rat nest I have ever seen...carcass count ended at 3 rats...
ID:	122168   Click image for larger version
ID:	122170   Click image for larger version
Name:	look ma no floor.jpg
Old 02-13-2011, 03:44 PM   #94
Silverfoxrae's Avatar
1957 26' Overlander
Saint Augustine , Florida
Images: 45
Wow. I just recently realized that there were different ways of doing the bellypan. I had been following a few restoration threads and then I started another and the 'stream was put together differently!
Rae
via~ AIR Forums App.
Metallicised.
AIR # 42703
TCT Member
TAC # FL~6
WBCCI # 1464
'57 Overlander thread:"the end of the rainbow is silver"
Silverfoxrae is offline   Reply With Quote
Old 02-13-2011, 04:32 PM   #95
Rae
On my '91...the channel is shaped like the below sketch...the plywood fits between the sections...it's important that the channel not collapse or the wood won't go back in!
For the '63...nothing wraps around the plywood...just an upward facing c bolted on top...
Name:	1991 channel.jpg
ID:	122172   Click image for larger version
Name:	1963 channel.jpg
Old 02-13-2011, 06:39 PM   #96
Oh yeah...how about this...
The week that I make the trailer un-towable...is the same week that I can offically Tow it!
Old 02-13-2011, 07:59 PM   #97
Klatawa (to travel)
Klatawa's Avatar
1965 24' Tradewind
Bremerton , Washington
Wonderful job! Pretty scary to take the shell off the frame. We did ours with the shell on, but we live in rainy Washington so it gave us some shelter from the elements.
Looking forward to following your progress.
Klatawa
(Dave & Debbie)
1965 24' Tradewind
2015 Chev Silverado HC
Klatawa is offline   Reply With Quote
Old 02-14-2011, 03:12 PM   #98
http://www.airforums.com/forums/f427...a-c-71140.html
Hi Alansd,
Post 13 of this thread has some pics for you. I heard about this from The Vap first, but I never saw pictures of it.
I found an AC that fit behind my old furnace shroud, so it's invisible when closed.
Cheers,
Rich the Viking
Old 02-14-2011, 03:21 PM   #99
Ottawa , ON
Thanks for posting those pictures of the channel, HiHo. Makes it much clearer!
You know, when you think of it, the end stuff should have been called a "U" channel!
Old 02-26-2011, 12:26 PM   #100
I can't say I'm making progress because we finally decided to stay home...we hauled the 34' to a local campground last night and spent the night...
I decided to come home and work on Dolly this morning...
Off comes the belly pan...pulling the front axle up on ramps shows the shape of the axles...they are locked in place...
just a few rivits, the corner jack bolts and some gas line screws....flop, down comes the pan...
I may pull the rear axle this afternoon...Hello, Axis? now I start spending money...
Name:	Good axles 2.jpg
ID:	123109   Click image for larger version
Name:	Saggy Belly.jpg
1963, overlander, restoration
