07-24-2015, 07:11 PM
#1001
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Dolly in Nolanville
Hey Y'all! Look who dropped by Top's Vintage Trailer Works the other day-
Thanks HiHo! It was a pleasure to see your wonderful Dolly. It is a beautiful trailer.
Lance
07-25-2015, 06:46 AM
#1002
Austin
Man that's one good looking trailer!
07-25-2015, 02:33 PM
#1003
Central
, Mississippi
A '63 Overlander Followed us Home
Attachment 243834
I enjoyed the visit and getting to see Abby and some of the work you are doing.
10-23-2015, 10:14 AM
#1004
59' Globester
1959 18' "Footer"
1957 26' Overlander
Three Rivers
Originally Posted by HiHoAgRV
Here's the closest bolt I have to the one I'm searching for. These would work except for 1) the end isn't self tapping and 2) the are almost $1 each at the big box store!
Yes, thats a Ronco tank I bought thru PlastiMart.
Axles? hummm...as you have seen, I've done the Dexter route - I have considered AXIS but have sent a couple of e-mails to Colin and never heard back. I'm still on the fence on that one. I hadn't thought about continuing the Shock vs no-shock but that may be possible...
Japan? nah...the folks found out I am restoring a '63 Airstream and figured I have a loose nut...they were looking for SMART folks!
I did get the wheel wells fitted and most of the holes drilled thru outrigger/floor and C channel. Awaiting on Epoxy and bolts. I'm supposed to be in Atlanta in a week or two...Aircraft Spruce may get to sell me some bellypan aluminum!
Hey Vernon,
what were the specs on those bolts? Did you find a bulk supplier?
did you find self tapping or did you use nut and bolt combo?
10-23-2015, 05:59 PM
#1005
Central
, Mississippi
Here is what I've used recently. They are self tapping on thin stuff like cross members but I had better luck on thick stuff like the main rails and cross members that I replaced with thicker tubular steel if I ran a tap thru first. I did add nylon lock nuts underneath.
10-24-2015, 08:17 PM
#1006
59' Globester
1959 18' "Footer"
1957 26' Overlander
Three Rivers
Here is what I've used recently. They are self tapping on thin stuff like cross members but I had better luck on thick stuff like the main rails and cross members that I replaced with thicker tubular steel if I ran a tap thru first. I did add nylon lock nuts underneath. Attachment 250921
thanks Vernon
I'm having channel made, getting plywood, paint and screws. Have most of the other stuff for now.
10-30-2015, 04:59 PM
#1007
Central
, Mississippi
Since Dolly was built in November, she got a birthday present this week. Well, really it is MY birthday present from Ms HiHo but who is counting?
10-30-2015, 05:55 PM
#1008
1971 21' Globetrotter
Arvada
Very nice I can't wait to install mine.
10-31-2015, 01:52 PM
#1009
Central
, Mississippi
It's pouring rain so I figured I'd run the wiring. The display will mount above the stove hood and the wires snake up into the false floor in the overhead cabinet, then toward the rear, thru a wall and into the hollow floating shelf above the bed and finally into the closet. The black tank is accessible here and the water heater drain hole is right at the gray tank in the belly pan. Also from the closet I run forward under the bed, below the kitchen cabinet and into the dinette where the fresh tank is located. I'm using 3x 22ga shielded wire.
The first hole I drilled pulled out blue plastic. Yep, drilled into the pex.
Grrrrrr.
Much to my surprise the black sensor actually reads thru the original fiberglass black tank! I doubt it will be 100% accurate and testing indicates this but it does read and the %full increases as the tank fills.
I'll have to wait for a dry day to install the gray sensor.
So far this is a fun, simple project (even fixing the pex wasn't too bad)
10-31-2015, 05:35 PM
#1010
1966 22' Safari
Hilltop Lakes
How did you find out when she was built?
Can you tell me how to find out when an Airstream was built? We've been trying to find the build date for ours.
Thanks.
11-01-2015, 10:17 AM
#1011
Central
, Mississippi
Thanks.
On some trailers, it's stamped on a plaque, I'm guessing yours isn't. Although I've seen conflicting statements, on my '63 the build date is the year followed by the month, 6211. Some folks say that it's year followed by week but a March 1962 build on Dolly doesn't add up. The '63's didn't start production until later in '62 so it's a good argument that 6211 is 1962, November.
My 1991 is pretty easy to decipher the build date. ;0)
11-01-2015, 10:42 AM
#1012
1977 25' Caravanner
Jeffersonville
, Kentucky
can anyone help with this VIN? Having trouble with the desipher
Movie Stars and Film Crews come to Me from hundreds of miles enticed by My knowledge, My imagination,expertise, creativity and innovations!
11-01-2015, 11:04 AM
#1013
Western
, Massachusetts
Originally Posted by scf31
Does it look like this?
11-01-2015, 12:52 PM
#1014
Central
, Mississippi
We had one of the hottest, driest summers on record so of course I was looking forward it cooling off. I've got a ton of work lined up so what happens? Yup, it cools off and starts raining on the weekends.
I got the internal wiring complete, the black and fresh sensors installed but it's just too mushy to crawl underneath for a :15 minute install of the gray sensor. I also built and installed a housing for the display.
The black sensor works much better than I hoped. The old fiberglass tank is slightly tapered so the edge is only about 3" tall. I used the JS sensor, cut to the shortest length and wrapped the lower edge around the curve and under the tank. At full, it displays 100% and drops to 0% just before the tank is empty.
Now I'm standing in the garage staring at the rain and all of the stuff that isn't getting worked on.
11-10-2015, 08:39 PM
#1015
59' Globester
1959 18' "Footer"
1957 26' Overlander
Three Rivers
I bought these today but looking back to page 10 you had used these?
I'm confused now...which is for what?
thx
Chip
11-15-2015, 04:52 PM
#1016
Central
, Mississippi
Yeah, I did use those but have switched. Those tended to snap off the head too easily.
04-10-2016, 01:24 PM
#1017
Central
, Mississippi
04-10-2016, 05:31 PM
#1018
Wildwood
How much did the set up cost you. Debating weather to take the leap or not...
Dave and Felicia
04-10-2016, 07:25 PM
#1019
Central
, Mississippi
$300.
$225 for the Renogy panels, $25 for the legs, $30 for the GoPower adaptor and I split a $40 roll of VHB tape with another friend.
Take into count that I already had the connectors at a couple of bucks each, I have tubes of sealant in the freezer (adds flavor to the frozen shrimp) and I had the heavy gauge wire.
There is nothing better than having a few watts of solar running all day. It suks having to sit at camp while the generator tops off the batteries.
I parked Dolly under the shed, went inside and was still getting enough solar to add .2 amps to the batteries. That offsets the 24/7 draw of my various displays.
04-11-2016, 10:24 AM
#1020
59' Globester
1959 18' "Footer"
1957 26' Overlander
Three Rivers
$300.
Hey Vernon, where did you get the panels?
all I see on Ebay is about $200 for each panel.
