Old 03-07-2011, 09:10 PM   #113
x
XXXX , XXXX
bent up. I love it.
I've been lurking and following your thread. If I ever finish mine I want to start looking for a 61 Sovereign to do. My dream is to do a 61 and have a 61 Lincoln convertible as a TV. That way the TV & A/S will be as old as I am. We can all creak and groan together into old age.
wasagachris is offline   Reply With Quote
Old 03-09-2011, 07:23 PM   #114
Central , Mississippi
"Sea", that was easy!
Actually...it only took :15 to recreate the rear curved "C" channel...
I re-assembled the pieces of the old channel and traced it on a board...
snipped the 1/2 "C" (angle) .032 on a 2" pattern...
Bowed it...then snipped the second piece of angle so the slits lined up...
riveted from the bottom...
and checked to see if it matched...!
ID:	124083   Click image for larger version
ID:	124085   Click image for larger version
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 03-09-2011, 07:26 PM   #115
Originally Posted by wasagachris View Post
bent up. I love it.
... My dream is to do a 61 and have a 61 Lincoln convertible as a TV. That way the TV & A/S will be as old as I am. We can all creak and groan together into old age.
We are on the same exact same 'schedule'...I am a year older than the actual build date of the '63...I out creak it!
Old 03-19-2011, 01:49 PM   #116
80 degrees today so I'm supposed to clean out the swimming pool...oops...I forgot
Time to flip the frame and get it ready for rust encapsulator.
An engine hoist on the bumper and the tractor on the hitch...Over she goes!
ID:	124885   Click image for larger version
ID:	124887   Click image for larger version
Old 03-19-2011, 06:06 PM   #117
Guess how much this frame flexes?
It's a 4" tall "C" channel version.
Here is the setup...rear axle removed so it almost ballances...very little tongue weight...that equates to maximum front and rear 'droop'...
slowly lifting the back end and supporting the tongue...
the bumper travels 5.25" before the axle clears the ground...remember, my axle is frozen solid...
I double checked the stuff with a lazer level and yup...5"+ of frame flop with no weight except the bare frame!
Name:	Flexi frame.jpg
Old 03-20-2011, 05:08 PM   #118
Paint! well, rust encapsulator...
I decided to weld on the gray tank supports even though it hasn't arrived yet. I also decided to drop the remaining axle so I could get everything painted. It does work pretty good when the frame can be rotated...
I used 1/2 gallon of Eastwood Rust Encapsulator...a few spots will need a second coat...
Everyone has heard of the blond haired beauty named Goldilocks...what about a grumpy old dude that spends way too much time messing with Airstreams...Alumalocks?
Name:	Gray supports.jpg
ID:	124974   Click image for larger version
Name:	Right size tools.jpg
Name:	Up frame.jpg
ID:	124976   Click image for larger version
Name:	bottom painted.jpg
Name:	Top painted.jpg
ID:	124978   Click image for larger version
Old 03-20-2011, 06:49 PM   #119
Ottawa , ON
Cute! lol!
Old 03-31-2011, 08:07 PM   #120
Some progress...I keep thinkin I'll be able to leave work at a reasonable time in the evenings and actually get some work done in the evenings....so far that hasn't turned out too good.
I did buy the plywood for the floor, still need to order the bolts and epoxy. I have decided to use regular ply and epoxy coat everything.
It looks good for salvaging 2 of the 4 corner jacks...the other two are going to be a challenge...POR15 to the rescue!
ID:	125837   Click image for larger version
ID:	125839   Click image for larger version
Name:	apart jacks.jpg
Old 04-02-2011, 09:12 PM   #121
Flooring day. Today I fitted all of the floor panels, cut the "C" channel to length and made the opening for the black tank dump valve. The dump valve was a challenge, I had to test fit the bath to see where the gray tank ended up.
I have ordered my epoxy, a 3 gallon kit = $150, it's due in this week along with the gray tank.. I still am looking for a source of the bolts I want, self threading 1/4-20, wide flat head #2 phillips...they are used in the later model 'streams...ideas?
Name:	im floored.jpg
ID:	125999   Click image for larger version
Name:	Find da drains.jpg
Old 04-02-2011, 09:56 PM   #122
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Moving right along Vernon,
Are you using the gray tank from VTS? Where are you using the self threading screws? VTS has some screws like this. I found the same exact screws from Fastenal. You aren't using elevator bolts and hex head bolts through the C channel?
Lance
Top is offline   Reply With Quote
Old 04-02-2011, 10:22 PM   #123
Hey Top,
I'm using this tank...20 gallons, $150ish plus shipping...don't get me started on the rip off 'shipping and handling' is now 'days...
The bolts I'm lookin for resemble elevator bolts...wide flat head...but it has a #2 phillips in the head AND the end is 3 or 6 sided like a tap...you have to pre drill but they cut the threads...reason?...some of my cross members are rectangle tubing...kinda tough to put a nut on the end! These do give me the option of nuttin the ones I can get too....I spent 1/2 hour in the Fastenall store Friday...ran out of time so I will play on their website while TDY...
Then comes insulation, new sheet aluminum for the bellypan and dump plumbin'...
Old 04-02-2011, 10:44 PM   #124
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Ok I understand. That looks like a Ronco drawing. Am I correct? That should work well.
I don't think I've ever seen a screw like you are describing. I'm sure you can find it from Fastenal or McMaster-Carr. You might want to call the 800 number and speak with the "support staff"
So, are you going to install new axles? Just kidding. I know you are. I heard your question on the VAP two weeks ago. I think It's your turn to try an axle from Al-Ko Kober. I haven't found anyone that has gotten an axle from them yet. You could be the first!
I also think you should do more testing with and without shocks on new axles when you have the Olander road ready.
TDY? Government worker huh? Where are you headed? Japan?
Lance
Old 04-03-2011, 12:03 PM   #125
Originally Posted by Top View Post
Ok I understand. That looks like a Ronco drawing. Am I correct? ...I don't think I've ever seen a screw like you are describing. .. I think It's your turn to try an axle from Al-Ko Kober. I haven't found anyone that has gotten an axle from them yet. You could be the first!
Here's the closest bolt I have to the one I'm searching for. These would work except for 1) the end isn't self tapping and 2) the are almost $1 each at the big box store!
Yes, thats a Ronco tank I bought thru PlastiMart.
Axles? hummm...as you have seen, I've done the Dexter route - I have considered AXIS but have sent a couple of e-mails to Colin and never heard back. I'm still on the fence on that one. I hadn't thought about continuing the Shock vs no-shock but that may be possible...
Japan? nah...the folks found out I am restoring a '63 Airstream and figured I have a loose nut...they were looking for SMART folks!
I did get the wheel wells fitted and most of the holes drilled thru outrigger/floor and C channel. Awaiting on Epoxy and bolts. I'm supposed to be in Atlanta in a week or two...Aircraft Spruce may get to sell me some bellypan aluminum!
ID:	126044   Click image for larger version
Old 04-08-2011, 08:29 PM   #126
Supplies have arrived. 3 gallons of epoxy (details forthcoming) and the gray tank are now in the garage. I still have to find some bolts to use...out of town all week and never had free time to web-surf for them. I hope the big-o-box stores have something I can use...
Next comes insulation, plumbing...
More photos as the floor install moves forward.
Name:	Gray Street.jpg
1963, overlander, restoration
