Old 01-22-2017, 01:18 PM   #1037
Central , Mississippi
Here is what one looks like
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-09-2017, 10:31 AM   #1038
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
I need that exact table if anyone has one.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 03-12-2017, 03:26 PM   #1039
A '63 Overlander Followed us Home
I was out camping last week and over a 5 day period, I had to relight the old original Bowen water heater 4 days. It's easy to tell when it's lit, the flaky high temp valve dribbles water out of the floor drain...
So it's finally time to upgrade the 54 year old water heater.
ID:	281304   Click image for larger version
Old 03-12-2017, 03:30 PM   #1040
Of course as soon as drain it (and create a swamp to work in) it starts raining. The new 6 gallon is much smaller, I'm going to need a 'hole shrinker'.Click image for larger version
ID:	281306   Click image for larger version
Old 03-12-2017, 03:35 PM   #1041
The plan is to keep the Bowen cover so I removed the sheet metal from the old tank and fit the new surburban into it.
ID:	281310   Click image for larger version
Old 03-12-2017, 03:39 PM   #1042
The WH was bolted in at an angle so the cover fit the slant on the side of the trailer. Then I modified the old cover to clear the new intake and exhaust
ID:	281312   Click image for larger version
ID:	281314   Click image for larger version
Old 03-12-2017, 03:43 PM   #1043
Once all of the old parts were cleaned up, I stuffed it back into the hole, attached the water lines, turned on the pump and 'squirt'...I had pinched a line during the replacement.
All in, it was a nice weekend project.
ID:	281316   Click image for larger version
ID:	281318   Click image for larger version
Old 03-12-2017, 05:20 PM   #1044
goransons's Avatar
1963 22' Safari
Looks great! We did that too on our 63 safari and love that I can flip a switch and have hot water!
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 03-12-2017, 06:59 PM   #1045
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 31
Good job saving the original outside water heater cover! Looks great!!
54 years has to be close to record for a working Bowen original round water heater.
Rick--Airstream of Mississippi www.foleyrvcenter.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 03-17-2017, 08:23 PM   #1046
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Nice job, Vernon. I did the same to my Bambi II & I still think it's one of my favorite "morphs". Nothing like flipping a switch for hot water!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 03-19-2017, 08:18 AM   #1047
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
Vernon, it looks great! You are one the most creative people I know about when it comes to blending the old with the new. Your ability to shrink the hole and keep the same exterior appearance is brilliant!
Steve
Steve Bryant is offline   Reply With Quote
Old 06-03-2018, 04:07 PM   #1048
I made a change to my solar setup. This started off with a 400w install on our 34' and flowed over to Dolly.
After installing the panels on the 34' I started to mount the new controller and prep for lithium batteries but I changed my mind, lithiums will go on Dolly. This means the new controller also needs to get installed in her. Out comes the Bluesky and in goes the Chinesium one. It's programmable so I can specify parameters and not have to buy the expensive Bluesky monitor. I'll put the Bluesky in the 34'. :30 swap and everything is good, as can be seen by the cheap looking happy face on the LCD...
ID:	312873   Click image for larger version
1963, overlander, restoration
