Old 01-07-2011, 07:56 PM   #71
Central , Mississippi
Originally Posted by Royce View Post
I would use the bandsaw and a jig.
Welllllllll....my $49 jigsaw just won't "cut" it...
But my table saw and jig might do the job...
It's too dark tonight...I'm gonna sleep on it and then tomorrow...let it rip!
ID:	118932   Click image for larger version
ID:	118934   Click image for larger version
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-07-2011, 08:42 PM   #72
And obviously it's too late...Jigsaw??? I meant Band Saw...my jig saw skills are not even an option for joinery cutting...
Old 01-08-2011, 09:01 AM   #73
Hummm...I thought this was about '63 Overlander but I've hijacked my own thread...
The cutting jig worked nicely...I guess I need to point out that I don't recommend using a table saw with out the shield
Anyway...here is what I'm thinking for the bath counter. I have to work out some details for the interior shelves since there is a hatch area that protrudes into the cabinet.
On Edit...I need to point out that this is a mockup...the worm holes won't be carried over into the final version...
ID:	118958   Click image for larger version
ID:	118960   Click image for larger version
Old 01-15-2011, 04:49 PM   #74
Being out of town all week puts a damper on progress...I managed to get most of the Bath Mockup done today...
Doors and Drawers will come later...along with a new top to fit the curve corner over the tub
The blue tape is where a round hole goes...underneath will be a trash receptical... a nice round cover over the top.
ID:	119328   Click image for larger version
Name:	Mock up 2.jpg
Name:	Mock up 3.jpg
Old 01-17-2011, 05:34 PM   #75
Progress made today...Kitchen Counter is the attack zone...I started by creating another 8'togon tube and lathing it round...Recreating the cabinet face and attaching the 90 degree segments and a side..
I'm liking the round corners a lot..
I guess it might be a good idea to try a test fitting...
ID:	119552   Click image for larger version
ID:	119554   Click image for larger version
Old 01-18-2011, 08:31 PM   #76
constructor's Avatar
1973 25' Tradewind
1960 28' Ambassador
New Smyrna Beach , Florida
Looking good.
Ann - The Constructor's scribe TAC FL-20
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover. - Mark Twain
constructor is offline   Reply With Quote
Old 01-18-2011, 09:15 PM   #77
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Wow! like the rounds... I need a shop...
Old 01-18-2011, 09:18 PM   #78
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Seconded, on both. I wish I had a 2bayer, or a 3bayer... Actually I can't wait to get a few pieces installed so I can work on others.
I'm am amazed at your craftsmanship. all I can say is wow! Your mock-ups look better than my final products.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 01-20-2011, 07:01 PM   #79
Testing Testing 123
Thank for the positive feedback...I also need a shop...you can see Mrs HiHo's car in the driveway...and a few posts back a view of my table saw shows my rippin' setup...in the driveway...
I got a test fitting last night...everything looks like I figured except one hickup...by straightening the cabinet so it's parallel to the wall I 'lost cabinet length'...so the drain on the left side of the double sink is centered over the top drawer and my plans for roller slides is an issue...unless I switch to a single sink...
Lobster bowl sink?
Name:	Kitchen Test Fit.jpg
Old 01-21-2011, 07:54 PM   #80
More test fitting...
I'm really dragging my feet because I don't want to start on the Doors-N-Drawers...
Hey! I can mock up the bed frames and the dinette!
For some reason, the photo adds rust that's really not there
Name:	Test fit Oven 1.jpg
ID:	119803   Click image for larger version
Name:	test fit oven 2.jpg
Old 01-22-2011, 02:19 PM   #81
Kitchen mockup is pretty much done. That's a lot of small pieces of wood!
I may get some 5/8 ply and make a top just for kicks...
Time to move on to the next piece...
Name:	Kitchen Test Fit 2.jpg
Old 02-05-2011, 05:05 PM   #82
Last night we had a light dusting of snow, but the sun was out so I decided to work on the exterior stuff today.
1st item of business was to tryout my new rivit remover to make the ceiling sheet metal managable. It is 2 pieces, each 4 ft wide and buck riveted down the middle...today it was to become 2 seperate pieces...the only tough part was dealing with all the latex paint...it was actually thick enough to clog the drill bit...I finally got the parts hung on the fence with some of the other pieces...
Then it was time to pull off the AC unit...it went much easier that I expected...actually a 1 man job if ya got the right stuff...30 year old ski rope is required...
the rest of the day was spent drilling out shell-to-c-channel rivets. I removed ALL of the wheel well rivets, then I used the fancy rivet driller to center drill each rivet head. The rivet tool tends to clog so then I used a standard drill bit to remove every other rivet in the floor c-channel. Slightly over 300 rivets drilled out today...120+ left to go before the Full Monty...
I really like the no-ac look
Name:	Big ceiling.jpg
ID:	121531   Click image for larger version
Name:	Rivit Drill.jpg
Name:	Split Cieling.jpg
ID:	121533   Click image for larger version
Name:	Off with the AC.jpg
ID:	121535   Click image for larger version
Old 02-06-2011, 04:35 AM   #83
VIKING's Avatar
Boulder Creek , California
Thats going to be a sweet interior. I love the fifties trailers with the rounded cabinets. Not so much in Airstreams, but in Spartan Manors and some others they were used extensively. It really adds character to the cabinetry.
I also didn't like the roof AC idea at all. I don't care if that's the only place an RV engineer can figure out where to put them, they're ugly and they look worse on an Airstream than on most white boxes. I installed a small window unit on a slide-out tray in my Safari and I'm really happy with the way it works. It's possible to get smaller units then they make for rooftop mounting also, so I sized one for my little trailer that's only about 18-1/2" wide and 15" tall and it works great. I can cool the interior on an 85-90 degree day parked in the sun, down to 64 degrees.
A few other cool things about it, I can run it on a single Honda 2ooo generator with power to spare, and I can replace it with a new one for $200 at Gnome Depot, or a used one for $50 off of Craigslist. Try that with a rooftop model. Oh, it has a remote control also, so I never have to get out of bed to mess with it.
Best to you,
Rich the Viking
VIKING is offline   Reply With Quote
Old 02-06-2011, 06:26 AM   #84
Ah, this all looks so familiar. Very nice work, keep it up!
1963, overlander, restoration
