Old 03-12-2017, 04:35 PM   #1041
Central , Mississippi
A '63 Overlander Followed us Home
The plan is to keep the Bowen cover so I removed the sheet metal from the old tank and fit the new surburban into it.
ID:	281310   Click image for larger version
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 03-12-2017, 04:39 PM   #1042
The WH was bolted in at an angle so the cover fit the slant on the side of the trailer. Then I modified the old cover to clear the new intake and exhaust
ID:	281312   Click image for larger version
ID:	281314   Click image for larger version
Old 03-12-2017, 04:43 PM   #1043
Once all of the old parts were cleaned up, I stuffed it back into the hole, attached the water lines, turned on the pump and 'squirt'...I had pinched a line during the replacement.
All in, it was a nice weekend project.
ID:	281316   Click image for larger version
ID:	281318   Click image for larger version
Old 03-12-2017, 06:20 PM   #1044
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
Looks great! We did that too on our 63 safari and love that I can flip a switch and have hot water!
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 03-12-2017, 07:59 PM   #1045
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 35
Good job saving the original outside water heater cover! Looks great!!
54 years has to be close to record for a working Bowen original round water heater.
Rick--Foley RV Center www.airstreamofmississippi.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 03-17-2017, 09:23 PM   #1046
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Nice job, Vernon. I did the same to my Bambi II & I still think it's one of my favorite "morphs". Nothing like flipping a switch for hot water!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 03-19-2017, 09:18 AM   #1047
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
Vernon, it looks great! You are one the most creative people I know about when it comes to blending the old with the new. Your ability to shrink the hole and keep the same exterior appearance is brilliant!
Steve
Steve Bryant is offline   Reply With Quote
Old 06-03-2018, 05:07 PM   #1048
I made a change to my solar setup. This started off with a 400w install on our 34' and flowed over to Dolly.
After installing the panels on the 34' I started to mount the new controller and prep for lithium batteries but I changed my mind, lithiums will go on Dolly. This means the new controller also needs to get installed in her. Out comes the Bluesky and in goes the Chinesium one. It's programmable so I can specify parameters and not have to buy the expensive Bluesky monitor. I'll put the Bluesky in the 34'. :30 swap and everything is good, as can be seen by the cheap looking happy face on the LCD...
ID:	312873   Click image for larger version
Old 10-17-2018, 09:53 AM   #1049
After 5 years the 6V golf cart batteries are down to about 50% capacity. Not bad especially since the charger is an old univolt! Admittedly the only reason I made it to 5 years is because 90% of the time the univolt is turned off and solar is taking care of the batteries. Time for an upgrade that costs 60% of what I paid for Dolly.
Old 10-17-2018, 09:59 AM   #1050
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I've known cars that double in value when you fill up at the gas pump! Yes, batteries are expensive, and the AGMs we put in even more so, but worth it!
Hopefully, you missed out on most of the fun with the latest hurricane.....
Kay
Old 06-09-2019, 09:00 PM   #1051
Rapid City , South Dakota
I suppose I am a tad bit late but I could use that cap with the garden hose fitting. My trailer is a 61 Bambi. I could also use the outlet fitting as I am going to try to make a fitting for it. It would be a lot easier than working under the trailer. Thanks Glen
fander is offline   Reply With Quote
Old 06-09-2019, 10:49 PM   #1052
Let me look thru my pile and see what I still have. '61 Bambi is a cool trailer!
1963, overlander, restoration
