Old 12-18-2010, 02:55 PM   #57
Central , Mississippi
I'm tired of sittin around waiting to heal up so today I pulled the rear endcap. There is only the water heater one interior panel left (just below the rear window) but it has some threaded rods coming all the way thru the wall...that will wait for another day.
The dent in the upper corner that can be seen in post #1 popped right out with only slight pressure from the inside. There is a slight ridge that remained...I can minimize it with a roller...I'm very pleased with how it came out.
Name:	rear cap gone.jpg
ID:	117216   Click image for larger version
Name:	rear dent gone.jpg
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 12-19-2010, 06:58 PM   #58
Back home this afternoon from an overnight outing in the 34'...I decided to pull a few screws from the Bowen water heater...in :20 minutes it was out and stored!
I'm getting very close to the ugly part...doin' the full monty...
Old 12-19-2010, 07:26 PM   #59
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
It's looking good though!!
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 12-20-2010, 10:17 PM   #60
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Yes. It's gone quickly. (A good thing injury and winter can be blamed from this point forward, a few months!)
Hensley Arrow. 9-cpm solo, 15-cpm towing
Old 12-26-2010, 09:28 AM   #61
Dolly had a good Christmas...
That darn book by David Winick is gonna slow things down a bit...too many good ideas!
Name:	Dollys Christmas.jpg
Old 12-26-2010, 06:18 PM   #62
Since it never got out of the 30's today, it's time to start on the interior rebuilds...I started by re-staging the bath components in the garage...
1st photo is exactly as it was dissassembled...the 2nd is the required upgrades...
Name:	as built.jpg
ID:	117991   Click image for larger version
Name:	as bulit with improvements.jpg
Old 12-26-2010, 07:53 PM   #63
_
lOOOkin gOOd vernOn...
at first glance the upgrade appears 2b ObviOus,
but upOn clOser inspectiOn
i c a flexible red hOhse near the thrOne
with a small camera On the end...
IF this thang is gOnna be hOOked tO the view bOx,
i dOn't wanna knOh what channel u r watchn...
cheers
2air'
Old 12-26-2010, 09:16 PM   #64
but upOn clOser inspectiOn ...
cheers
2air'
Dang Electrical upgrades gone off track...all I wanted was a plug for my Television...
http://www.airforums.com/forums/f205...tml#post881641
Old 12-26-2010, 09:30 PM   #65
goransons's Avatar
1963 22' Safari
umm where's the magazine rack and mini fridge in there?
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 01-02-2011, 08:25 PM   #66
We made it home about 2:00pm today from the last 2010 camping trip, giving me enough time to start a bath cabinet mockup. One of the few things I find tougher than plumbing is wood working...this time I just going to PLAN on building the stuff twice! I'm starting out with large chunks of rough cut pine, ripping it to size and planing it smooth.
I am going to try for some rounded corners and slightly upgraded cabinet doors, along with some minor dimensional changes so I'm going to mock up stuff with the pine before I tear into the 'good wood'
Name:	Bath mockup.jpg
Old 01-05-2011, 09:31 PM   #67
Its wet and chilly so I'm going to play with some interior options...I want round corners on the woodwork...I know I can buy curved plywood but I usually try different methods so here goes one...
My bath mockup needs a round corner to transition over the tub...so I cut and glued a 6"dia x 3/4 thick hex...then I used my lathe (it REALLY hurt to turn wood on my metal lathe!) to round it out...
now I need a plan to slice it into 4 - 90 degree sections...
ID:	118834   Click image for larger version
Name:	hex round.jpg
ID:	118836   Click image for larger version
Name:	Hex sanded 2.jpg
Old 01-06-2011, 11:48 AM   #68
VIKING's Avatar
Boulder Creek , California
Safe and easy way is with a jigsaw. Table and band saws are not as safe or easy to use with curved parts.
Rich the cabinetmaker
VIKING is offline   Reply With Quote
Old 01-06-2011, 11:52 AM   #69
Maybe build a large box jig that wrapped entirely around it, with a slot on the top wide enough to drop your circular saw blade through? Not sure if you can get the required depth on that though...
Anyway, your turned "column" is looking great. It'll make for some very sturdy corners.
Old 01-06-2011, 03:26 PM   #70
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
[QUOTE=HiHoAgRV;.... now I need a plan to slice it into 4 - 90 degree sections...[/QUOTE]
I would use the bandsaw and a jig.
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
1963, overlander, restoration
