Old 03-03-2014, 10:16 PM   #961
Central , Mississippi
Shocking, huh? ;0)
Remember Steve Martin in "The Jerk" dancing around when the phone book arrived? I'm somebody!
Well, I'm doing the same dance but its an EBay win...
"I won, I won!"
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 03-03-2014, 10:25 PM   #962
reinergirl's Avatar
Hollis , New Hampshire
Nice score! I was one of the watchers . I actually have one, its the rest of the antenna I need!
I wish I could prove it with pictures of the auction ( darn why didn't I think of that!) but my recent score on eBay was the globe to the porch light see below, $15 I think I one upped you!
I just scored a second one for my sis off etsy too!
reinergirl is offline   Reply With Quote
Old 03-04-2014, 08:04 AM   #963
Attachment 206786
I figured that there was a bunch of us '63 owners watching those auctions...
$15 is a good score, the last one I saw was asking a bunch more than that. I have one exactly like that, it was in the trailer when I bought it.
Old 03-04-2014, 12:52 PM   #964
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
me too. I found mine under the bed next to a dead crow.
I love those little porch lights
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 03-10-2014, 04:20 PM   #965
I just got home from the freight terminal with Dolly's new axles. I seem to always inadvertently select the optional "only send 3 grease caps so I can call back and get the 4th" every time I order new axles. ;0)
No big deal.
My biggest concern is the weather. Its so nice right now I may go camping instead of installing axles!
Old 03-15-2014, 12:02 PM   #966
Why do simple tasks always seem to cause the biggest headaches? All I needed to do was seal a drip in the water tank fill line. It turned out to be a cracked fitting. Out comes the tank...
ID:	207524   Click image for larger version
Old 03-15-2014, 12:28 PM   #967
Before I start crawling the old inter-web, any suggestions on installing a new fill fitting? The old one appears to be glued in place, not spin welded.
Old 03-15-2014, 04:54 PM   #968
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
Vernon, I have repaired polypropylene tanks with a big soldering iron (like 200 Watts - big gutter soldering iron). I was able to just fuse the plastic together using heat. They also make plastic repair kits like this one at Amazon http://www.amazon.com/Rigid-Plastic-...tic+repair+kit.
You can also get new fittings tanks, I'd try Tractor Supply.
Sent from my SM-N900V using Airstream Forums mobile app
Steve
Steve Bryant is offline   Reply With Quote
Old 03-16-2014, 05:00 PM   #969
I don't know why I didn't think of Tractor Supply. I'll loop over there tomorrow, I see they carry bulkhead fittings and I have a removable port in the top of the tank so I have access to install one.
I spent a few hours making parts for my antenna rotator. The inner part is a different model than the outer so I'm adapting.
ID:	207622   Click image for larger version
Old 03-19-2014, 04:31 PM   #970
Tractor Supply to the rescue! Thanks for the suggestion Steve. Since I have a 6" clean out port in the top of my tank I was able to insert a bulkhead fitting thru the wall and attach a new 1.25 barbed fitting.
Old 03-19-2014, 11:28 PM   #971
1991 34' Limited
Wichita , Kansas
You are very welcome, sir! There's no charge for suggestions.
I like what you are doing on fabricating antenna parts too. Last winter or spring, I rebuilt my Braund antenna and had to fabricate several parts (nearly all replacement parts are unavailable now). That's the sort of thing that I really like to do. Here's a custom spring/thrust washer installer that I made for that job.
Old 04-08-2014, 11:33 AM   #972
Updates: The water tank rebuild has worked great, no leaks!
The antenna rotator is on hold as I await a replacment 10-24 tap. I broke my last one building new little wheels that contact the pole and rotate it. One thing I don't like about Amazon - when ordering a bunch of stuff I can never figure out the shipping cost of individual items. After confirming my order, I discovered I paid $11 in shipping for the $2 tap.
Hopefully this weekend will be dry for both days. I hope to get the new axles installed. My '63 has the same issue that Frank brought up here:
http://www.airforums.com/forums/f437...up-104400.html
So welding will be required!
Old 04-11-2014, 06:01 PM   #973
Tomorrow is work day. Dolly is up on the ramps and I'm hoping for a smooth axle swap. A note of interest, the 50 year old axles have loosened up a bit with use, the ramps are 4" tall and I barely got the front tires off the ground.
Lets see, remove 2 flare nuts, drill 7 rivets, pop hubcaps, remove tires, remove brake wires, remove 4 bolts and out comes axle #1.
Weld on 4 mount extensions and coat with paint.
Install axle #1...what could possibly go wrong?... ;0)
Old 04-12-2014, 10:48 AM   #974
1991 34' Limited
Wichita , Kansas
I'm going to be watching this closely as I'll be doing a triple axle swap this summer. I hope that all goes smoothly!
Old 04-12-2014, 11:07 AM   #975
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I thought you'd already replaced your axles.
Good luck with them, ought to be a piece of cake for you!
desertair27 is offline   Reply With Quote
Old 04-12-2014, 11:46 AM   #976
One down, one to go. :20 to get the front axle out. Then I welded on the plate extensions, that was no fun. 3 1/3 hours and the first one is installed
ID:	209499   Click image for larger version
ID:	209501   Click image for larger version
Old 04-13-2014, 03:58 PM   #977
The last axle, propane lines and brake wiring took 2 1/2 hours. I left off the hubcaps to retorque the lugs after a few miles. Since Dolly was hooked to the truck, a test ride was in order AND it was a pretty day... Mac and I grabbed a few things from the fridge and went camping at a local State Park!
Dolly tows different, I no longer can feel her hit small bumps and the bathroom garbage lid didn't end up on the floor.
The To-do list is getting shorter, Dolly will be ready for a big trip out west in a few weeks!!!
ID:	209601   Click image for larger version
Old 04-13-2014, 04:33 PM   #978
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Where you going out West, HiHo? Might we see you at VTA? That would be so cool!
Kay
Old 04-13-2014, 09:51 PM   #979
Kay
We are heading to the Tetons, perhaps the Big Horn Mountains. Yet another Big Adventure...
VTA sounds cool...
Old 04-13-2014, 10:00 PM   #980
reinergirl's Avatar
Looking good, am following your antenna rebuild closely as it's on my "to do" list
1963, overlander, restoration
