01-05-2014, 05:14 PM
#921
Hollis
, New Hampshire
Originally Posted by Minno
Is that one of those "I meant to do that" photos?
Kay
I knew it...y'all also have Red Necks!
Ah yup, I had to pahk the cah in the yahd.....
01-05-2014, 06:21 PM
#922
Wildwood
Nice!
Dave and Felicia
01-05-2014, 07:33 PM
#923
1964 17' Bambi II
Schererville
, Indiana
why two pix, I have no idea.....
Shelly, I'm going to read your posts in a altogether different accent than I had been!
Rednecks in Mississippi??? Naah...
Becky
1964 Bambi II
1988 Avion 32S
01-06-2014, 05:12 PM
#924
Central
, Mississippi
Depending on the particular weather forecast, its going to be somewhere between 8 and 15 degrees tonight! I have 2 small cube heaters running in Dolly and they are holding +30 degrees over the outside temp, even with the winds blowing so I hope nothing freezes.
The 34' camper has central heat set on 45 and a small cube heater, 1 full 10 gallon propane tank so unless something goes kaput, it should be of also.
This is friggin cold! Just to think, 6 days ago we were camping.
01-06-2014, 05:38 PM
#925
Hollis
, New Hampshire
We have a different idea of cold, our HIGH tomorrow is 15. We are seeing negative numbers at night..... We actually hit 40 today and I was in short sleeves
I tried to work on insulation today but the door lock and bolt were both frozen
01-06-2014, 06:24 PM
#926
1964 17' Bambi II
Schererville
, Indiana
....and our high was -12 degrees today. Tomorrow a heat wave of 0! This global warming is ridunkulous!
Becky
1964 Bambi II
1988 Avion 32S
01-06-2014, 08:04 PM
#927
Central
, Mississippi
I've been in -18 before, the paint fell off of the inside of the hotel door when I closed it.
Luckily ALL of my water system is PEX and above the floor because the only ice I like is in an adult beverage...
Anyone have an idea how long it takes for a Zipdee awning to be built? That's the only question I didn't get answered.
01-06-2014, 08:18 PM
#928
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
I don't know how long, but they build them just west of Chicago, so they are most likely hard frozen at this point!
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
01-07-2014, 04:59 AM
#929
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Typically two to three weeks from order to delivery.
Lance
01-20-2014, 05:22 PM
#930
Central
, Mississippi
Originally Posted by 65CV
Pics or it didn't happen...
Here ya go. 1 1/2 weeks and it was AT the dealer!
Of course it's about to turn cold again. Hopefully next weekend will be nice and I can get it all installed.
01-24-2014, 05:15 PM
#931
Central
, Mississippi
With some luck, we will be installing the awnings tomorrow...actually I have already done the rear one. It and the street side are only a matter of replacing the canvas since the "Vintage 1972 Zipdee awnings" ;0) are still there. The big curb side awning was dumped on the side of I-55 by the PO so it will be a complete install.
Photos to follow...does anyone want to see specific details? (I want to see a final photo!)
01-25-2014, 03:41 PM
#932
1991 34' Limited
Wichita
, Kansas
Vernon,
Even if there's little interest in pictures now, I believe it would be helpful to folks in the future for you to document it. The way I see it, our forum threads serve those who follow them in the present and they are a time capsule for those searching out information in the future. It can kind of be like Back to the future!
01-25-2014, 04:19 PM
#933
Central
, Mississippi
Here's a few photos. I got the new sunbrella on the two small awnings. It's pretty easy and zip dee has good instructions. Remove the awning using caution on the left end of each one, it's the side with the spring. Drill out the rivets and slide off the cloth. Slip on the new cloth then reinstall the awning before you rivet on the cloth. Once you are happy with the way everything fits, drill new holes thru the cloth and tube then rivet. The final step is to remove the left arm and wind the spring 1 turn for every foot of awning length.
I didn't get the big one installed. The inside of the door was looking pretty messy so out came the polish. The next thing I knew I was using the cyclo and F7 on the outside. I may get the entire curb side done tomorrow, it's been 2 years and really needed a touch up.
01-25-2014, 04:24 PM
#934
1964 17' Bambi II
Schererville
, Indiana
Your awnings look fantastic, Vernon! I'm not gonna lie....I'm pretty jealous that you can go outside & polish now....all I see is white (and it's not sandy beaches....for now!)
Becky
1964 Bambi II
1988 Avion 32S
01-26-2014, 09:27 AM
#935
Nowhere
Awnings look very nice. I'd love to see a write-up on your installation of the curb side big awning. That's a project I'm hoping to tackle somewhere down the line.
Norm
01-28-2014, 08:33 AM
#936
Central
, Mississippi
White like this? Polishing one day, snowing two days later. Crazy
01-28-2014, 08:37 AM
#937
Central
, Mississippi
Norm
I'll post some steps and photos. I actually started the install but the arms didn't fit properly. There was a mixup at Zip Dee and even though my package was marked AS1 hardware, the contents were for a '89 or later trailer. After a few calls and photos, Zip Dee confirmed the mixup and now we are working out how to get them swapped out.
02-01-2014, 05:26 PM
#938
Central
, Mississippi
Here is how measure for a Zipdee. The critical dimension for ordering is the center rib to center rib, front to rear. On my trailer it's 191.5". This is also where the lower brackets mount, the 2 screws go into the same line as the rivets. The up/down dimension on my kit is 71.5" down from the awning rail slot.
While checking out the rest of the parts, I found out that one of the lock down wheels wasn't threaded all of the way thru. Luckily I have a tap/die set and was able to fix it.
When ever my new arms arrive I'll post the next steps.
02-01-2014, 10:25 PM
#939
1991 34' Limited
Wichita
, Kansas
Vernon,
Did you try to seal the screws and rivets with anything? These things can leak like a sieve as you are probably well aware!
Steve
02-02-2014, 07:38 AM
#940
Central
, Mississippi
Originally Posted by Steve Bryant
Vernon,
Steve
Good point, yes these things DO leak like crazy if they are not sealed during assembly. The brackets on my 34' poured in water because the installer didn't seal anything.
On stuff like this, I dry fit and then use blue painters tape on the shell around the perimeter of the bracket. I then remove the bracket, bed it with Trempro, then reattach. The trempro oozes everywhere but the tape keeps it from making a huge mess. Wait a couple of hours and peel off the tape. If I have used pop rivets, I add a small dab into the center to seal it. I keep saying that I'm going to use a hole punch and some tape to make a 'mask' to stick over the pop rivet before dabbing on the trempro but I never have. An old rivet stem is a pretty good tool to dab with.
