Old 01-02-2012, 07:49 PM   #365
reinergirl's Avatar
Hollis , New Hampshire
Wow! What progress I'm totally green .. Just a few questions as usual LOL what are u planning to do with the fiberglass end caps now that you've decided not to paint (right?). And how will you cover the gap in the center of the ceiling? Inquiring minds want to know..... Are you happy with how the skins went in and what would u do differently?
Love it, you are one of my "must click on threads" !!
reinergirl is offline   Reply With Quote
Old 01-02-2012, 08:06 PM   #366
Central , Mississippi
Originally Posted by reinergirl View Post
.. what are u planning to do with the fiberglass end caps now that you've decided not to paint (right?). And how will you cover the gap in the center of the ceiling? Inquiring minds want to know..... Are you happy with how the skins went in and what would u do differently?..
Yeah, ya noticed...as of NOW, the center gap will be covered by a strip of matching Cherry...possibly inlayed with LED's...
End caps...still working that one, BUT the leading choice is something like the new 'Streams...speckle paint? How's the progress coming at Colins? ('green with envy face' inserted here)
Originally Posted by Steve Bryant View Post
... However, the swinging arm would be nice about positioning it where you want it for viewing.
Steve, the 'hole' AVI panel thing came from a need to cover a really ugly vent...and a bit of envy of my Pal's $1/4M RV with the outside Television. IF I hang an arm, it will only be while we are parked...the only need for an arm is to hike the TV from behind the door (when it's open)!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-03-2012, 11:54 AM   #367
Sometimes you are REQUIRED to recycle...
The tub P trap was in pretty bad shape so I figured heck, I'll just replace it...guess what? No short P traps are available in my area. Luckly I was able to find a split nut and get the original stuff working.
Oh yeah, I'm doing plumbing now. The gray tank is installed, holes cut in the floor and a large inventory of odd shaped PVC fittings have been purchased...keep our fingers crossed...me and plumbing, we ain't the best of friends
Name:	Tub Trapped.jpg
ID:	148199   Click image for larger version
ID:	148201   Click image for larger version
Old 01-03-2012, 03:40 PM   #368
Oh, I missed a photo! The bath drains are roughed in and tied to the gray tank, vents have been re-fit. The original walls were dug out of storage, set in place and will be marked for use as templates.
Name:	Wall test fit.jpg
Old 01-03-2012, 07:25 PM   #369
reinergirl's Avatar
Hey Vernon,
Me again!. I know I heard on The Vap not to long ago that it's common to reuse that tub drain because it's hard to find! I think it was Tim who was bemoaning the fact that he had POR 15'd the outside of it but not the inside so sometimes if the tub drain backed up or drained too slowly he got rust/sediment in the tub. You might want to POR it!
On a closer look yours look like brass? In which case ignore this as brass won't rust!
Another question of course!. Do I see the tub drain pipes above the floor? Running in front of where the tub would be, along with the vanity sink drain. How would that work? My tub drain is below the floor. I'm confused ?
Old 01-03-2012, 08:06 PM   #370
Hey Vernon,
Hey Shelly,
yeah, mine is brass and I'm relieved it was in good shape except for one nut. With the new 'split nut' I'm good to go!
Routing...my original (well, the way it was when I got it...) had the tub drain into the P trap and loop back above the floor, cross under the sink then dive thru the floor about in the middle of the trailer. Once below the floor, it required a huge hole cut into the street side frame rails to get to the dump valve..I didn't like that part of the big hole/frame...
So yes, I'm running it forward (about the same distance it originally went across) and dumping straight into the top of the tank.
The original sink drain went toward the tub, under the lip and forward into the curb side closet, tied into the vent and then went down, reversing it's route under the tub at floor level and finally tying into the tub drain just before diving thru the floor!
Oh yeah, I had to create an insulated box below the tub P trap, didn't want it hanging into the belly pan and freezing!
Old 01-09-2012, 07:43 PM   #371
Yuck...more plumbin'
I liked the brass inlet but have no intention of using a pressurized tank, so the inlet is getting reconfigured. My tank is moving...it will be under the dinette...and as it just so happens...there is a puncture in the skin EXACTLT where the new inlet needs to go...
I cut off the old brass fill tube (which says "P Revere Red Brass" and polished up really nice!!!) and will epoxy it into the outer trim ring. First I'm sealing the joint with Vulcum so the epoxy doesnt run everywhere...
Name:	Holy shell waterman.jpg
ID:	148614   Click image for larger version
Old 01-10-2012, 07:05 PM   #372
More plumbin'
sanded the tub in prep for epoxy paint...Almond color...never used 'Rustoaluminum' tub paint before so keep our fingers crossed
City water inlet showed up.
ID:	148688   Click image for larger version
Name:	Tub Paint.jpg
Name:	City Water.jpg
Old 01-10-2012, 08:48 PM   #373
Ottawa , ON
I used that on a bathtub in the house. Tried it twice, lots of sanding in between. Lousy results.
Don't bother with trying the brush, apparently the only way to get a smooth coat is to spray.
I gave up and had a pro do it; what a difference!
ps: what's the flush mount plug for?
Old 01-10-2012, 08:57 PM   #374
Aage,
Thanks for the feedback...I have a $20 gravity feed sprayer that is now going to sacrifice itself for the project...spraying will be the way I go!
"Flush plug" is a city water inlet to replace the 5' of old garden hose, clamped to a swollen piece of previous frozen copper pipe that served as the previous city water connection...
Old 01-13-2012, 05:44 PM   #375
It's cold outside so I'm back to working in the garage. Time for cabinets...I layed out the cuts and sliced 3 cherry boards, I have enough for the bath and kitchen fronts. The main structure will be pine. I needed to scarf joint some pieces into longer sections, got that drying right now.
I've never had the chance to work with cherry...the grain is so fine it's like MDF...
If the sun warms us up tomorrow, I will spray epoxy paint on the tub and plane the Cherry to the proper thuckness.
Name:	Cut Stock.jpg
ID:	148824   Click image for larger version
Name:	Scaft Joints.jpg
Old 01-14-2012, 02:37 PM   #376
More stuff done on the "day time" list...
I needed to move my power inlet, it's location wasn't ideal...rain water pours off of the awning and would run directly onto the inlet.... I moved it just rear of the water heater. The city water connection went into the empty hole. Of course the water connection was a tiny bit too small so I had to make a patch...
The water fill is now located in the front street side (where a big dent was), the water tank will be under the dinette. The brass tube is going to polish up nice.
I sprayed the tub and brushed the toilet stand...they came out lookin pretty good in Ivory color.
I also pulled the door skins...its easier to replce them than clean off all of the paint...SURPRISE! the Bargman lockset has a sticker...Made in China!!!
Name:	in the drip line.jpg
ID:	148879   Click image for larger version
Name:	Moved power inlet.jpg
Name:	Water inlet.jpg
ID:	148881   Click image for larger version
Name:	Water fill installed.jpg
ID:	148884   Click image for larger version
Name:	Made in China.jpg
Old 01-15-2012, 05:55 PM   #377
Today was supposed to be easy...reskin the door. Figured I'd chek out the China Bargman L-100 before reinstalling and found all of the screws were loose...for a REASON! If the were tight the dang thing jammed up......so i spent several HOURS getting it to work properly. I did get the door done.
Name:	Dor skinned.jpg
Old 01-15-2012, 06:31 PM   #378
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
nice work on the fill tube! Are you going to to plug the old air valve hole on it or use it as a vent? Our fill tube is aluminum unfortunately, and fairly pitted. With your set up at least the fill line can flex with the hose rather than rigid to the tank. We resealed the inside of our original tank but know that joint you sealed and will epoxy will forever be prone to water leaks and thus checked often. Your attention to detail is inspiring!
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
wally:Restoring Wally Byam's 1955 26' European Caravan Trailer!
goransons is offline   Reply With Quote
1963, overlander, restoration
