Old 04-25-2011, 08:09 PM   #141
Central , Mississippi
The bolts finally arrived! :30 minutes later the floor is bolted to the frame, the side "C" channels are attached and it's time to flip it over for insulation, gray tank install and then the belly pan. A couple of lucky phone calls turned up a local supplier of 4 x 10 x .025 3003 aluminum for $42 per sheet.
So what is holding up the progress?
Camping in the 34' Headed for Charleston for a week...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 04-25-2011, 08:30 PM   #142
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
That is a great deal! Enjoy your trip.
Lance
Top is offline   Reply With Quote
Old 04-30-2011, 09:08 PM   #143
You have heard "when the stars align"...well, when "2 stars" get involved...so much for vacation...
I can tell you...the poor folks in South MO are having a BIG problem...and it ain't a shortage of water...
Charleston and vacation...maybe next week...
Old 05-08-2011, 12:13 PM   #144
Dolly must of gotten a new outfit in the mid 1970's...here is the ZipDee paperwork that was in her.
Ya think the pricing is still the same?
Name:	Zip Dee Page 1.jpg
Old 05-25-2011, 05:29 PM   #145
After almost a month of no progress...today I snagged 6 sheets of .025 3003 for $42 each...It's time to flip the chassis and do the belly pan...
I still gotta grab some rigid insulation and brake wires...
Old 05-26-2011, 07:09 PM   #146
For the first time in a month...the frame/floor is rolled out of the back yard and flipped over. It's all leveled up and I went ahead and cut some floor pan sections to test fit. I have to get the foam insulation in the next day or so, install it...brake wires...some plumbing...gas lines...
Hummm...maybe I'll just hook to the 34' and go camping again
Name:	floor going up.jpg
ID:	130761   Click image for larger version
Name:	over and down.jpg
ID:	130763   Click image for larger version
Name:	testing the belly.jpg
Old 05-28-2011, 07:21 PM   #147
Insulation time...
I'm not that wound up about floor insulation...3/4 ply plus a 1" air gap then a section of R4 foam...lots of tape to seal the gaps...
Cutting foam with a table saw is, um, interesting...the blade sorta melts thru and if given a chance...will grab the foam...keep your fingers clear!
Name:	Insul Spacers.jpg
ID:	130923   Click image for larger version
Name:	1 sheet.jpg
Name:	2 sheets.jpg
Old 05-28-2011, 09:06 PM   #148
x
XXXX , XXXX
Looking great Vern. Man that is so much easier when you're not fighting gravity. Building it down side up is the only way to go.
wasagachris is offline   Reply With Quote
Old 05-28-2011, 10:15 PM   #149
1968 26' Overlander
West Richland , Washington
Slick method for installing insulation and bottom skins. What have you got in mind for the gas lines that stub up threw the floor? Drill them? From the top or bottom?
JIMandPJ is offline   Reply With Quote
Old 05-29-2011, 07:49 AM   #150
Yeah, this way when I drop something, there is at least a small chance it ends up in the location that was intended. I don't know about ya'll but I've gotten to the point where I hate working over my head even though I tend to get into things-over-my-head quite regularly...
Old 05-29-2011, 07:55 AM   #151
Gas lines...hummm....yeah, I plan on running the thru-floor sections as I install the interior. I can't see a show stopper with using a long 1/4" bit as a pilot hole thru the wood and belly.
That plan leaves me open to do some last minute adjusting of the interior. For instance, I'm still considering moving the water heater to a forward position and eliminating the forced air furnace, both of those choices will impact my gas line routing.
Old 05-29-2011, 01:31 PM   #152
More progress...
All the pieces are cut and removed, the center section spacers are glued in place. I ran out of adhesive...
It looks like the Pink Panther exploded in my driveway...
ID:	130995   Click image for larger version
Name:	The pink panther exploded.jpg
Old 05-29-2011, 02:47 PM   #153
nmbosa's Avatar
Nowhere , Washington
Very nice looking work. I have found myself wishing I spent a little more time focusing on the underbelly insulation. I was in a bit of a rush at that point of the project and did not seal it up as well as you are doing. Our floor is like a sheet of ice on a cold morning.
Norm
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 05-29-2011, 05:19 PM   #154
Thanks for the positive feedback...I can say one thing without any hesitation...
My hat is off and I salute the folks that have done the insulation and belly pan from underneath! This is day #2 for me, working with the frame inverted and I cannot imagine getting this done - much less doing a good job - while laying on the ground!
I ran out of washers...tomorrow we have friends over to cookout...anyone wanna bet if I can stay away from the project for a full day?
Name:	Screwy washer.jpg
ID:	131009   Click image for larger version
Name:	made in the usa.jpg
1963, overlander, restoration
