Old 09-11-2014, 08:43 PM   #521
Heliguy63's Avatar
1964 28' Ambassador
henderson , Nevada
How did you clean off all the old paint off the window hardware?
Heliguy63 is offline   Reply With Quote
Old 09-11-2014, 10:43 PM   #522
reinergirl's Avatar
Hollis , New Hampshire
I covered each one in Citrastrip, enclosed it in a freezer bag, left it for a couple a of days ( not by design but I just didn't get back to it!) And then used a toothbrush and 3m grey pads to take the paint off. Seriously my best ( ie most used ) purchases so far have been my scaffolding and a carton of 3m grey scotch brite pads. Product Catalog&#160Scotch-Brite‚ĄĘ Ultra Fine Hand Pad 7448, 6 in x 9 in, 20 pads per box 3 boxes per case¬*: Electrical Commercial and Industrial: 3M US
Oh, and plastic razor blades, love them!
PS, after they were stripped I used a degreaser to get the original grease on the crank out, spray painted, then sprayed a silicone lubricant on the gear. Do NOT use the silicone before the spray paint ( ask me how I know! ).
reinergirl is offline   Reply With Quote
Old 09-11-2014, 10:49 PM   #523
Heliguy63's Avatar
1964 28' Ambassador
henderson , Nevada
Awsome! Thanks! I will use that method for sure. Especially sense my P.O. Got a little carried away with the white paint.
Old 09-11-2014, 10:59 PM   #524
reinergirl's Avatar
By the way I just realized the picture of the scare light was version 101. Originally, I tried using cork as a gasket. Major fail, I ordered the butyl tape from VTS and redid. One of the many items I've done more than once.... Learn from my mistakes grasshopper..
Old 09-12-2014, 04:55 AM   #525
Baltimore , Maryland
You said Marinco inlet, but it is a Furrion in the photo. There is about a $75 difference there. I use the Furrion inlets myself.
Old 09-12-2014, 09:47 AM   #526
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
You can get a blue lens and LED bulb from VTS for your scare light. We saw one at the MN Airstream Park and bought one. Looks KOOL! All your wonderful exacting work puts us to shame, esp in the polishing department. We've done hardly anything there, and still aren't sure how much we want to polish....
Kay
Old 09-12-2014, 12:42 PM   #527
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
they sell those lenses at truck stops
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 09-12-2014, 08:51 PM   #528
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Looking GREAT, Shelly! I love those vents. I actually was washing out my black tank with my Flush King for about the third time and wasn't paying attention & and a shower come out of my bell-type vent like yours! Never fear, I have a no-poop-policy! lol!!! It was nicely sprayed over the whole rear of the trailer....
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 09-14-2014, 08:43 PM   #529
reinergirl's Avatar
Hehehe at least if you get a bee nest up there Becky you'll know how to get rid of it
Old 09-14-2014, 09:31 PM   #530
JCPOTTERF's Avatar
1963 28' Ambassador
Danielsville , Georgia
I added the Marinco outlet. By the way, I used a rubber gasket that I cut last year turned out it was already cracking so I found this at the local Orange Box store, closed foam seal, fit perfectly, even the screw hole punched in the foam lined up! They also fit perfectly under the wedding cake tail lights. I'll re-purpose the metal plate that came with them.
Great thinking on the gasket did you replace those wedding cake lights? my bases are rusted out but lenses are ok. Just wondering what streamers are doing for replacements
JCPOTTERF is offline   Reply With Quote
Old 09-14-2014, 09:53 PM   #531
reinergirl's Avatar
I not only replaced the wedding cake lights with ones from VTS (mine came with truck stop models) but took them LED, like reggiemon did in this thread
http://www.airforums.com/forums/f447...emy-52497.html
It's NOT for the faint at heart, you have to drill into the stainless backplate with a hole saw, and put a larger hole in the trailer skin. Plus the LED needs to be enlarged/ filed at the screw holes to get it to all fit..... The upside is it's a completely sealed unit, no corrosion and LED are vastly superior to the standard OEM bulbs.
Ask my how I like it when I actually light it up for the first time
Old 09-15-2014, 06:15 PM   #532
JCPOTTERF's Avatar
1963 28' Ambassador
First of all thank you! Sorry I meant to use the quote tool above.....Then I seen your blog invite (Very Nice )40 minutes passed and thanks again! The ambassador and over lander are much alike. I am trying to make mine a tent by August for Sturgis !
Old 09-15-2014, 08:35 PM   #533
reinergirl's Avatar
You're welcome! Good luck! I'm hoping to paint in the spring and finally get some miles on Moonraker .
Old 09-16-2014, 07:07 PM   #534
reinergirl's Avatar
I found something really exciting when I was cleaning up the interior wheel wells. Someone had written something on the fiberglass! I've seen other peoples posts about uncovering cool notes and signatures inside the walls of their Airstreams. At one point, I considered taking apart my door because it is often signed by one of the workers....then I came to my senses!
Anyway, I thought how cool! I finally have something! The trouble was I couldn't read it as they signed the backside of the wheel well and plated over it with a piece of aluminum ,so it was a very faded mirror image I was seeing from underneath . Nothing would do except taking it all apart!!!! So I did! Once I wiped all the grime off I could finally see what it said....wait for it...
Can you see it? Come a little closer....
Now?
It says "REJECT" Well, that sucks ....just saying....
The search for evidence of her builders continues. I need to think about how to leave my mark for future owners ....
Old 09-16-2014, 07:30 PM   #535
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Now?
Too friggin funny!
Colin
Colin H is offline   Reply With Quote
Old 09-16-2014, 08:26 PM   #536
Becky B.'s Avatar
1964 17' Bambi II
Hope you don't get a complex or anything...... I wrote a note on the interior of the exterior skin of when I remodeled it. In another 50 years maybe someone will find it...!
Becky
1964 Bambi II
1988 Avion 32S
Old 09-16-2014, 11:23 PM   #537
reinergirl's Avatar
I already have a complex! Like my trailer can only be viewed between 5 and 7 pm...... Morning sun sucks and has no bearing on my polishing skills. Seriously
Old 09-19-2014, 08:58 AM   #538
Minno's Avatar
1972 31' Sovereign
OMG, that is so funny! Gave me a very good laugh!
Kay
Old 09-20-2014, 10:21 AM   #539
Central , Mississippi
Re: J, E.C.T.
After all of this work, someone named "J" is gonna need Electroconvulsive therapy (ECT)
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 09-21-2014, 06:22 PM   #540
reinergirl's Avatar
Originally Posted by HiHoAgRV View Post
Re: J, E.C.T.
Good one HiHo, I think I'm going to need ECT too!
NEEDED: Two front windows for '71 Overlander jesse_kevon Windows, Doors, Locks & Vents 4 05-30-2015 10:26 AM
Need Door for 1961 Overlander BentMetal 1960 - 1964 Overlander 9 07-28-2011 05:36 PM
Need Refrigerator Compartment Door for 1972 Overlander jazz1945 Exterior Storage Compartments & Access Doors 1 05-30-2011 03:50 PM
My 1963 Overlander Exterior Corle0ne Cleaning, Stripping & Polishing 3 04-29-2011 11:25 AM
should i buy a new toilet for my 1963 overlander? harrison Sinks, Showers & Toilets 3 04-26-2011 05:42 AM
