Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1958 - 1963 Overlander
Old 09-21-2004, 06:42 PM   #1
Silverfly
Silverfly's Avatar
Profile:
Thumbs up The $8 Porch Light
I like porch light! I had a little time and made one today. Here it is in all its glory! By lossening the lock nut you can rotate it to whichever position you want. The rotary switch above the curbside bed finally has a use!
Name:	The $8 porch light.jpg
1962 Overlander International
Silverfly is offline   Reply With Quote
Old 09-21-2004, 07:00 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
OK, then. Fork over the details on how you did this, wouldcha?
Uwe
Old 09-21-2004, 07:25 PM   #3
Silverfly
Silverfly's Avatar
Profile:
Lightbulb
O.k. Here goes... Acquire:
  • 1-3 prong male plug (one with necked down wire end)
  • 1-single outdoor fixture (the one with 1/2"thread and the cover)
  • 1-PVC 1/2" conduit bushing
  • 1-tube 2 part epoxy
  • 1-light bulb (your choice of color)
Assemble it in the store to make sure you have the right parts.
  1. Open light fixture package and discard the box cover and gasket.
  2. Use the epoxy to glue the plug into the conduit bushing, rough up the inside of the bushing and the outside of the plug for maximim adhesion.
  3. Feed wires through the bushing and thread it onto the light fixture.
  4. Wire the plug, insert into its housing.
  5. Plug it in adjust the position with the lock nut.
  6. Turn on and enjoy (If you skipped ahead and installed the bulb)
'Porch' Light Replacement Fixture with 1141 Bulb AirConditioner Electrical - Systems, Generators, Batteries & Solar 1 07-06-2005 09:22 PM
64 Globetrotter Patio Light Problem sdresen Lights - Interior & Exterior 1 07-26-2004 11:27 AM
Brake/Turn Light Wiring Question (late 70's) DPeakMD Electrical - Systems, Generators, Batteries & Solar 3 07-14-2004 01:46 PM
Dent and replacing light fixtures imeynstein Lights - Interior & Exterior 5 03-30-2004 02:56 PM
help me see the light wheel interested Our Community 1 11-17-2003 08:34 AM
