Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1958 - 1963 Overlander
Old 09-20-2004, 05:15 AM   #1
Silverfly
Silverfly's Avatar
Profile:
62 O'lander Bathroom Light
Hi There, I am missing the curved lens for my bathroom light in my 62 overlander. What is it supposed to look like? Can somebody post a picture so I can find/fabricate one? Thanks
Silverfly is offline   Reply With Quote
Old 09-20-2004, 07:55 AM   #2
flyfshr
ModeratorMan
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Hey Silverfly,
I believe I have the same light fixture but mine is missing the lens and the left end panel. Can you post a picture of yours? If I had the end panel, I was thinking of using a cut down piece of those 2' x 4' recessed flourescent light fixture covers. They are readily available in home centers and should be flexible enough to curve to the needed shape. A little applied heat could convince them if needed.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 09-21-2004, 05:04 AM   #3
Silverfly
Silverfly's Avatar
Profile:
Here is a pic of mine. The lens idea is a good one, I am currently working on the Airstream so I may give it a try in a day or so. I will let you know the results.
Name:	62 Overlander light.jpg
Old 09-21-2004, 07:34 AM   #4
fireflyinva
fireflyinva's Avatar
Profile:  1961 22' Safari
Vienna , Virginia
Hello,
I have a few of these fixures (bathroom, bed, iirc) in my '61. The covering is very much like the white flourescent light covers--and I understand it's a satisfactory substitute. For the accuracy obsessed, the original light cover is made of translucent white plastic (I think the surface is formed in thin parallel ridges). You may have to search far to get an exact match, but I think the regular replacement flour. light covers you can get at Home Depot will do fine, even if the pattern is slightly different. I don't know how you could cut it, though--you may need to use a saw, since it's a little too brittle for snips and too thick and hard for a razor.
Mary
fireflyinva is offline   Reply With Quote
Old 09-21-2004, 11:17 AM   #5
61Overlander
61Overlander's Avatar
Profile:
61 light fixtures
Here's a picture of my original light fixtures, the twin bed lights are exactly like the bathroom fixture. They are as described, white translucent plastic with thin ridges. Mine are going to be replaced, and so far I've been unable to find them. I was checking old electical fixtures in small town hardware stores whenever I travel, I remember seeing those fixtures being common. Until then you can make do with the flexible acrylic sheets, they bend enough to work, you can use a dremel to cut em, and a hair dryer to assist in the bending. My ratio is 3 broken attempts for every successful one, so go ahead and buy the large sheet of plastic. It's only 4 bucks or so. Mike
61Overlander is offline   Reply With Quote
Old 09-21-2004, 06:53 PM   #6
Ken J
Profile:  1958 26' Overlander
Tijeras , New Mexico
I've tried to use those flourescent panels - they are very brittle and do not bend well, so I gave up on them.
Ken
1958 Overlander
Ken J is offline   Reply With Quote
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 08:01 AM
lenses for bathroom light atvmcg Parts Archive 2 03-10-2004 11:20 PM
help me see the light wheel interested Our Community 1 11-17-2003 07:34 AM
Night light Pahaska Our Community 5 11-12-2003 07:15 PM
Bathroom light cover alori Parts Archive 5 10-28-2003 11:38 AM
