Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1958 - 1963 Overlander
Old 09-27-2004, 01:35 PM   #1
Over59
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
59 Plastic Tub
So I am making slow progress. Some frame problems under a sound floor, now that should make everyone a little nervous.
The tub is plastic and the end cab inside rear is fiberglass.
The tub has an 1/8 drill hole in it, don't ask. Will fiberglass stick to the bottom of the tub if done right or is someother stuff better.
I will be patching holes in the cab and reinforcing some areas with fiberglass setup.
Looks like l'll need a welder also.
ID:	8878  Click image for larger version
Let those who can play, let those who cann't rule.
Over59 is online now   Reply With Quote
Old 09-27-2004, 01:50 PM   #2
Ken J
Profile:  1958 26' Overlander
Tijeras , New Mexico
Yea - when I took my interior out I found the bad spots in the floor - my frame is good though - so I agree I've learned that even if the floor looks good, it may not be.......
Ken
1958 Overlander
Ken J is online now   Reply With Quote
Old 09-27-2004, 03:51 PM   #3
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
I would think fiberglass would work if done correctly as long as its not a Poly proplene or simular plastic. If that is original then I would think it is not plastic. Plastic was not widely used back then. That was still the time of Bakalite. Bakalite would not have been used for something that size.
Our 59 the shower pan is fiberglass but it looks like plastic from the top.. I would think yours is fiberglass as well but it may just be gel coated on both sides and look like its plastic.
Reguardles as long as what ever it is is not a material that is prone to continual skinning like a Poly propelene is it should work fine. Just be sure to sand the area where you want the material to bond. Fiberglass does skin when it cures out and you have to sand past that layer and then it will bond quite well. www.westmarine.com is where I have been getting my glass stuff. That have a good network of stores and may be one close by. Little pricy but conveinent for small quanites.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 09-27-2004, 04:01 PM   #4
flyfshr
ModeratorMan
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
In all of the '59 and '60 model years I've seen, the tubs were all made of fiberglas. Check underneath or the backside for the telltale fiber material, its there. These tubs were really strong and durable. I put a tub from a '63 Flying Cloud in mine because the original was really cracked. The tub from the FC was 2" shorter in length but I got it to work out.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 09-27-2004, 09:33 PM   #5
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
Dome is Fiberglass. The tub looks like and feels like plastic, top, bottom, and edges. This appears to be a very late 1959 trailer as it has that 1960 badge on it. Alast I'll prep a stop on the underside and test it. Maybe a little sanding will show the fabric. Still haven't figured out how to get the P trap off. The drain has no cross pieces to hold on to. I may have to cut between the tub and the top of the piece of floor I cut out and deal with the drain stem in the P trap afterwards.
Anyone need a hot water controll or knob. It clicks when turned that's all I know.
Alternate exterior plastic parts repair IPM Bumpers & Bumper Storage 2 01-24-2008 10:46 AM
Plastic Plumbing 83Excella Fresh Water Systems 6 05-04-2006 01:16 AM
Plastic inner skin on 1973 Sovereign? malconium General Interior Topics 6 06-06-2004 05:34 AM
How do I remove the Tub??? Morning Dew Interior Restoration Forum 18 04-19-2004 10:47 AM
plastic repairs and paint ALANSD Cabinets, Counter Tops & Furnishings 3 02-09-2004 01:21 PM
