Old 06-25-2010, 08:31 AM   #1
1958 22' Caravanner
Pueblo West , Colorado
Airstream Title
I was given an 58 Flying Cloud about 10 years ago, and I have had it sitting on my hunting property since then. I brought it home about a year ago and fixed it up. I got everything working and repaired all major problems and am ready to try it out. My problem is I don't have a title for it and the old man died about ten years ago. I never planned to use it anywhere except my hunting property but it was to nice to let die.
Can anyone tell me where the vin number is? I have numbers on the hitch and the plate on the side of it. I will have to apply for a title and was wondering what was the easiest way to do that. (Lost Title etc.)
Ron in Colorado
ID:	105555   Click image for larger version
ID:	105557   Click image for larger version
Ron Banks is offline   Reply With Quote
Old 06-25-2010, 08:42 AM   #2
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I can't say what is permitted in Colorado, but I can tell you how it is done here in AZ. I bought a non-titled Honda CB350 motorcycle at auction for $80. I called the DMV and they provided me the name and address of the most recent owner. I had to send a return receipt signed letter to him asking him to release the title. It came back as undeliverable, so they went ahead and let me get a new title. Maybe because it was only a small motorcycle and it was only $80.
The Airstream plate by the entry door has your serial number and it should, depending on factory, be:
Ohio | ~O-3500 to O-3544
(I prefix for Int'l options)
California | 8350+, also 22-85NN late
(same as Safari & Customs)
Nice trailer you got there. Hope this helps.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 06-25-2010, 08:43 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Hi Ron. See Vintage Airstream Photo Archives
From all the streetside windows, are you sure you don't have a Caravanner? Compare that to the '58 FC pics. Your wheel wells are Ohio type and not from the California plant. In the top left of each of those pages are VIN samples.
So for a '58 FC your VIN would look like:
For a '58 Caravanner your VIN would look like
Ohio | ~O-9300 to ~O-9399
The sequential production number would be 3500-3544 for a FC and 9300 to 9399 for a Caravanner. So which is it?
At each of those pages, there are other models to view; eg, 1958CalFlyingCloud2, 1958Caravanner2, etc. That will get you a broader sampling for each aspect of the window layout.
5 meter Langford Nahanni
Old 06-25-2010, 08:50 AM   #4
Sorry ... yes, the plate by the door is the number you would use.
Old 06-25-2010, 09:13 AM   #5
bevman's Avatar
1958 22' Flying Cloud
Saint Helena , California
I'm with BobStream. Looks like a Caravanner. Good luck with the DMV! I had a tiny bit of difficulty convincing them that my VIN number was only four digits. I had the trailer in the parking lot and said, "Wanna come take a look?" Apparently that would have required getting up. The agent just took my word for it and processed the papers.
-Michael
TAC CA-12
"All things in moderation, including moderation"
- Mark Twain
bevman is offline   Reply With Quote
Old 06-25-2010, 09:18 AM   #6
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I'm also with BobStream. Unique Caravanner windows.
FF
Old 06-25-2010, 09:32 AM   #7
1958 22' Caravanner
Hi Guys,
Thanks for your help! By the door is says Flying Cloud and O-3514. Someone told me that it had the caravanner option. It has a different layout inside, with two gocches. It is a nice old camper and I have tons of work to do on it. It is perfect for hunting and I do alot of that. Thanks Again.
Ron
Old 06-25-2010, 08:51 PM   #8
Well... your VIN sure falls within the Flying Cloud range as noted on R.J.Dial's Vintage Airstream Photo Archives. He has done his research very well but still gives the ~ 'approximate' symbol about ranges of VINs. 'Approximate' within the range of human error. VIN 3514 is early to middle in the '58 production sequence.
They're all 22' models. The Caravanner began in 1957. I have no reason to say this, but I suspect the factory may not have had it clear whether they had separate Falcons, Flying Clouds, Customs, World Travelers or Caravanners. Differences with the Santa Fe Springs, CA, factory didn't make it any easier. Or plain just got this one wrong.
I think you can feel comfortable calling it a Caravanner from here on. Two gauchos. Fold away when you have a crowd over. Party Airstream!! That's the high sign for Caravanner all the way IMO...
Old 06-25-2010, 09:22 PM   #9
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
You could visit the Pueblo County clerk and ask the license plate person what to do. They may not know. There's a person at DMV headquarters, now in Lakewood I believe, who handles title questions. The one I spoke to in 1996 when I had to get a Colorado title for a Florida car knew how to do things, but the person at the Jefferson Co. clerk's office didn't have a clue. You'd think that title question would be simple, but who knows how these people are "trained"?
To arm yourself with answers, you could visit the library and check the Colorado Revised Statutes. The Vehicle and Traffic Code will have answers about this sort of question somewhere. Since my copy is 4,000 miles from where I am, I can't check it now. The Statutes are online too.
Gene
Old 06-30-2010, 07:42 AM   #10
1958 22' Caravanner
Thank for all the help!
Bob Stream, you are right, it is definatley a Caravanner. comparing the pics, it has all the same stuff. It just has a Flying Cloud plate on it. The old man who ordered this unit wanted a flying Cloud and they just put the plate on it.
Thanks again
Ron
Old 06-30-2010, 07:49 AM   #11
1971 23' Safari
Bedford , Texas
I did the same thing recently. I got a bonded title. The local courthouse did a title search, there was none, the local DMV did a VIN search for registration, there was none. I had to have an insurance company issue a bond then submit that issued bond to the local subcourt house that deals with titles. The title will say Bonded which last for 3 years then drops off. I was issued plates and am good to go.
chronoboat is offline   Reply With Quote
Old 06-30-2010, 08:27 AM   #12
Yeah, and gave it a FC VIN too. They'd been producing Caravanners for a couple years by this time. Either it was deliberate to match up with his order or human error. Wouldn't matter either way I guess.
Ron, I changed you to '58 Caravanner in your profile if you don't mind.
Regarding the 'O' or 'I' (International) prefix in these 1950s VINs -- the 'O' was just a placeholder and had no significance. It would be changed to 'I' with the Int'l package which gave more mobility -- 12v coach power, onboard water and some other traveling amenities IIRC.
Old 06-30-2010, 09:40 AM   #13
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Read Colorado DMV's requirements . . .
Can anyone tell me where the vin number is? I have numbers on the hitch and the plate on the side of it. I will have to apply for a title and was wondering what was the easiest way to do that. (Lost Title etc.). Ron in Colorado
Hi Ron:
Go to:
Department of Revenue - Division of Motor Vehicles:
and read the state's requirements for obtaining a title.
Then go to:
http://adm.elpasoco.com/NR/rdonlyres...dingpacket.pdf
and download the bonding packet.
Generally, you have to complete and file an application for a title. You may have to obtain a bond or provide other security (bank account, etc.) for obtaining a title. Bonding is not generally required for "vehicles" (which includes travel trailers) 25 years old or older, like yours. See C.R.S. 42-6-115(b). But that exception depends on your giving the state a notarized bill of sale within 2 years of the vehicle transfer, which has long since passed. But given the age and low value of the '58 Airstream, the DMV in its discretion might waive the bond requirement.
Download the applicable forms, fill them out, gather all the necessary papers (including a VIN inspection of your Airstream) and take them to the DMV. Discuss your situation with them with all papers in hand.
The applicable statutes can be found by copying and pasting each of these separately in Google:
C.R.S. 42-6-115
C.R.S. 42-6-116
Good luck!
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Charter Associate Member FCU
Airstream Life "Old Aluminum"
47WeeWind is offline   Reply With Quote
Old 06-30-2010, 09:43 AM   #14
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
That's a beautiful '58 you got there. Welcome to the club. One of the first things I would do would get rid of the diamond plates on the front.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
1955 Airstream Safari 22 ft w/original title eBay Watch Airstreams on eBay 0 03-23-2010 05:20 AM
Airstream title luver Title, VIN & Registration 1 11-19-2009 10:13 AM
2005 airstream trailer /damaged good title eBay Watch Airstreams on eBay 2 11-07-2009 03:42 PM
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
