Old 04-17-2012, 09:53 AM   #1
cuyeda's Avatar
Long Beach , California
Hehr window crank hardware needed
This thread is also posted in the windows section of this forum.
Looking for window crank replacements for a 1958 Traveler. I believe the windows are Hehr. Disregard the added brace on the arm. Previous owner tried to fix it. All four of my windows need the crank with the arms.
Vintage Trailer Supply has one that is close, but not the same. The measurements seem to be the same except for the end of the arm that goes into the track.
VTS has a 9/16" button on the end, where as, mine seem to have a 1/4" nylon bushing on each side of the arm.
Clearview Operator
I also need the track (17") that goes on the window, and vertical mounting frame piece.
1947 Curtis Wright
1958 Traveler 18'
cuyeda is offline   Reply With Quote
Old 04-17-2012, 10:55 AM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Did you look at the ones here:
Inland RV Center Inc.
Old 04-17-2012, 07:04 PM   #3
cuyeda's Avatar
Yes, I was at Inland RV yesterday. The replacements they have do not fit my specific model windows.
1947 Curtis Wright
1958 Traveler 18'
Old 04-17-2012, 07:11 PM   #4
cuyeda's Avatar
Note: I did not know where to actually take the measurement on the arm. The ruler is just a reference of length. I may have moved it taking a couple of the photos. Both VTS and Inland RV has a crank that have the same measurements, but the end of the arm has a larger 9/16 button/disc on it. The nylon bushings are 1/4' each side.
1947 Curtis Wright
1958 Traveler 18'
