Old 03-31-2012, 12:54 AM   #71
Chlyman's Avatar
1958 18' "Footer"
Danville , California
I agree, I hate the windows too. Luckily there are a lot less on the Airstream. My Kenskill has 6 double hehr standards and and 4 singles. That is a lot of cleaning and polishing!!!
That sticker that I have been working on is quite difficult!!! The Goo Off only seem to melt the black part of the sticker off. So then I was looking at a clear round sticker on the door. Then I did a scary thing (for me!) I got my torch out and melted a little bit at a time. Now I am trying to polish the rest off. It is not an easy process!! I still have another one to do also, and this one is on the rear endcap. Not sure I want to use the torch.
I tried to sand my left rear teardrop lens. It is the original and dull. It was only marginally successful. I ended up putting some marks in it from the heat of the polishing wheel!
I have had a lot of trouble with the new window. The right side of the skin opening was not cut square, so when we bucked the rivets they turned sideways, making an enormous hole in the window frame. So now I am putting a piece of metal in front of the window frame and behind. I also ran out of rivets after figuring out the fix, so those arrived today. Hopefully we can move on!
Also took out the door knob to help with the polishing. Can't tell what was there originally by looking at the cut shape, but I think it was supposed to be the Bargman H-20. Long gone now!
Worked on the emblem a little. Not as professional as I was looking for!
It is supposed to rain tomorrow, so might not get any thing done!
ID:	154680   Click image for larger version
ID:	154682   Click image for larger version
Carolyn
1956 Caravanner Forum link
1958 Traveler 18 Footer Forum link
1955 Kenskill Rebuild link
Chlyman is offline   Reply With Quote
Old 03-31-2012, 03:02 AM   #72
salzburg , salzburg
wow that looks great i'm going to read your whole thread tonight!!, great shine!, how do you re-paint your emblems like that?
mrgreen is offline   Reply With Quote
Old 03-31-2012, 05:43 AM   #73
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Nice looking work! I think windows are everyone's least favorite thing to do!
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 03-31-2012, 08:31 AM   #74
Chlyman's Avatar
1958 18' "Footer"
For the emblem, I followed several other members recommendations and taped off the vin number, then sprayed it with Rustoleum Royal Blue. Then gently scraped and sanded the raised areas. Then cover it with a clear coat. I always think things are going to be easier than they are!
Carolyn
Old 04-02-2012, 10:47 PM   #75
Chlyman's Avatar
1958 18' "Footer"
Yesterday I got ready to add the access door for the future refrigerator. It is scary to cut an opening into new skin! But I did it anyway! I also started working on making my other vented panel into an access door.
I wish I could work on it all the time! The only thing I had time to do today was screw in a lens into the front side marker.
I also finished the kitchen window. It is so nice to have that back in. I did have to fabricate a new clip to hold the screen on. The little end breaks so easily on the old ones!!!! I just need to add one piece of weather stripping and it will be all done!
ID:	154909   Click image for larger version
ID:	154911   Click image for larger version
Carolyn
Old 04-30-2012, 11:26 PM   #76
Chlyman's Avatar
1958 18' "Footer"
Not much going on in the Airstream lately. Cold weather, rain, made working no fun. Then realizing the big Pismo Rally was so soon, and I have a lot to do on my Kenskill before going. In the process of building a shower pan for the third time. Hopefully this is the last time and I really want a prefab one for the airstream! I hope to get some ideas at Pismo, but I have never seen a Traveller there or anywhere but Oregon.
Carolyn
Old 05-01-2012, 08:04 AM   #77
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Great work! I never heard anything more about your axle...from the one pic you posted on page 3 of the bellypan, looks like it's all together again. I again think that you have WAY too many spring leaves on that springpack. I bet your trailer would both ride better and be higher if you took out two of the smaller leaves.
Bet if feels good to be along this far!
Marc
Old 06-13-2013, 07:36 PM   #78
Chlyman's Avatar
1958 18' "Footer"
Wow, I took almost exactly a year off! Late summer last year I got a "frozen shoulder". Made it impossible to work on the trailer. It has been getting much better, so after The Pismo rally last month I got back to work. I took out the roof vent and decided that might be the easiest time to polish what I could reach on the roof. Trying to get pits of oxidation out of the aluminum is a whole different beast than the regular polishing! I had no idea how aggressive I would have to get! I started with the G9 Nuvite, and to think I was worried about that being too aggressive by the 8th time going over the same spot!
I did some research here on corrosion, and then proceeded to attack it with sand paper. First 400, then 320, then down to 220, I was working on it for hours. I was worried about sanding through the cladding, but I think it's all ok. There are still some pits around the rivets. I didn't want to sand the rivets down to nothing. After the sanding, I have gone over it with the g9 about 4 times so far. It is finally looking acceptable. Still a way to go. It really surprised me how difficult this was and how many hours this one roof panel is taking. The next panel on the street side is even worse. I am not looking forward to that!
ID:	188226   Click image for larger version
ID:	188228   Click image for larger version
ID:	188230   Click image for larger version
Carolyn
Full Monte or not? I get what I deserve! Chlyman General Repair Forum 12 10-04-2011 07:48 PM
Valuation of 1958 Traveler? corinnedavid Trailer Values 11 08-14-2011 11:41 PM
New '59 Traveler Owners klhbeetle Member Introductions 4 07-28-2011 04:26 PM
Switching over to full tank problems melbel LP Gas, Piping, Tanks & Regulators 11 05-29-2011 06:25 PM
Full timing in the great white north hankyknot Full-Timing 8 05-06-2011 10:59 AM
