Old 10-14-2013, 07:28 AM   #15
Toddzilla's Avatar
1958 17' Pacer
Damascus , Oregon
We got it home.
I knew there was going to be some floor repair in the back, we pulled the bed and frame out. . . . crap.
Time for a complete replacement. Oh no, it's starting.
Front corners are also very soft.
and the sweet 110 circuit.
ID:	197759   Click image for larger version
Toddzilla is offline   Reply With Quote
Old 10-14-2013, 01:06 PM   #16
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
And you were thinking maybe no repair needed after just 55 years? Looks pretty good all things considered! Now would be a great time to make a template!!!!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 10-14-2013, 01:54 PM   #17
Toddzilla's Avatar
1958 17' Pacer
Damascus , Oregon
I knew there would be repairs.
I just hope it holds together before we get it replaced.
Old 10-14-2013, 08:06 PM   #18
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
fyi the floor tiles are asbestos
kevinb is offline   Reply With Quote
Old 10-14-2013, 08:15 PM   #19
calais66's Avatar
1951 21' Flying Cloud
Sacramento , California
This is the fun part! Just think about the rock solid trailer you're gonna have when it's all said and done!
calais66 is offline   Reply With Quote
Old 10-15-2013, 06:33 AM   #20
Toddzilla's Avatar
1958 17' Pacer
Damascus , Oregon
Thanks for the heads up Kevin. I hadn't thought of that.
I can pop them off, or pull up the wood with them intact, just don't cut them with a saw. Correct?
Has anyone read this article about body-on floor replacement? seems doable.
Floor Replacement - Vintage Airstream
Old 10-15-2013, 07:53 AM   #21
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We did shell-on floor replacement in our '72. It was very doable for us. I'm not sure what differences there would be for a '58. There would be advantages in a shell-off though. Belly pan is a big one and putting in tanks if they are under floor is another. It's a small trailer though.
Kay
Old 10-15-2013, 02:04 PM   #22
1966 17' Caravel
The J or U channel is attached to the floor and through to the frame so it is doable but tricky. Really not that difficult to brace and lift the shell even if you do not remove the frame from under it and it will allow you to repair any damage to the outriggers. 2X6 braces and a couple of 4X4 X12's some cinder blocks will get you there. Hope that helps and as for the tiles you are correct just do NOT use a saw on them.
Cliff
Old 10-15-2013, 02:14 PM   #23
Toddzilla's Avatar
1958 17' Pacer
Damascus , Oregon
Cliff,
Can you point me to a thread on bracing, if I go that route?
I've seen pictures, but haven't seen anything in depth on bracing.
Todd
The Dog House - http://www.airforums.com/forums/f104...er-111301.html
Old 10-15-2013, 02:31 PM   #24
pbearsailor's Avatar
Port Hadlock , Washington
Todd, I did a shell on replace on my '57, so it would be the same for yours.
The biggest downside like Kay said is the belly pan and it is especially true for our 50's trailers. The far and away best way to do our belly pans is shell off and with the frame flipped over. Shell on, it is an absolute pain trying to fit the four corners working upside down and trying to fit the sections inbetween the shell and the C channel/subfloor. On the other hand, I did mine outside and without and shop, so it is nice to be able to do the work under the shelter of the shell.
Read the long threads around here and you will learn so much about the issues you are going to run into. Make plans for what you want your trailer to be and what you'll want in terms of electrics, holding tanks, etc.
Looks like you've got a great shell and all your windows, so you have a great trailer to work with.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 10-15-2013, 02:37 PM   #25
1966 17' Caravel
Todd, I have seen the same threads as you an decided to do it my way! You have 4 L braces attaching the main side rails to the J channel, these side rails or ribs are thicker than the rest. Measure across from side to side and cut your 2X6 to that length. You want the end of the 2X6 to stop 1/8 inch from the outside wall attach the wood to the rib with some 1/4 inch bolts then run an angle brace up 2feet from the 2X6 to the same rib. How high for the 2X6 is easy 8inches or 1 cinder block high. Attach a second brace to the other set of ribs same as the front. Then run 2 2X4's equally spaced from front to rear under both 2X6's to the ribs in the end caps, since the 4x4's go under these you will need to screw these to the bottom of the 2x6's. Once you have all of the rivets and other attachments off (including the hidden rivets) use a hydronic or car jack a raise the shell raise the 4x4's with the cinder blocks on the outside. If you remove the frame remember to lower the shell a couple of blocks to make it a little more wind resistant. Hope this helps and if you have questions please ask I type like a 3 year old.
Cliff
Old 10-15-2013, 07:24 PM   #26
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
Did mine very similar to that article, and would do it the same way again. But I only did rear 4'. Personally the more I can leave unmolested the better I like it. But there are definitely pros and cons.
Be sure to read Steve's thread on his caravanner restoration, lots of good info there.
kevin
Old 10-17-2013, 02:43 PM   #27
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Hey Todd
Congrats on that super sweet trailer. I've been trying to buy that baby for the last couple of years. Even with the floor rot it's such a cool one owner trailer. Fingers crossed the frames not too bad a shape.
Steve's aka Pbearsailor thread is awesome! Very informative and touching, a must read!
Good luck on your trailer and hopefully you'll be able to keep it as original as possible.
Mike
desertair27 is offline   Reply With Quote
Old 10-17-2013, 02:58 PM   #28
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Yeah, what a great trailer! I did a shell-on replacement too, 3 of the four panels but not the rear-most with all the electrical and stuff. I did it myself, dropped the belly pan, but mine was much, much worse than yours so removing the existing floor was pretty much just using a shop vac. Where the floor was rotted, I used a bolt cutter to cut the bolts, used Marine plywood with a two part penetrating sealer and on and on. I think if you can take the shell off, it'll actually be quicker and easier to replace the floor.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
1958, 1958 pacer
1958 Pacer Ariz-Pacer 1958 Pacer 42 11-26-2018 01:02 AM
Vintage 1958 Airstream Pacer eBay Watch Airstreams on eBay 0 08-03-2009 11:50 PM
1958 airstream camp trailer Model Bubble or Pacer eBay Watch Airstreams on eBay 0 04-14-2009 08:50 AM
1958 Airstream Pacer Restored - NO RESERVE eBay Watch Airstreams on eBay 0 02-15-2009 07:31 PM
