Old
Update after a long winter, New house, new daughter!!
Posted 07-15-2015 at 07:34 PM by johnamjr
We have been busy with life but its time to get back on it. We Gutted the rear bath before winter. We need to repair the rotten floor, black tank frame and valve (thanks Out of doors mart). New metal hold down rear brackets had to be made up. So the Floor is back in and it seems we have just begun. Welded up new black tank brackets. Por-15 Chassis coat on all the of the steel i could get too under the floor. All new insulation under the floor. All new frame for the black tank and new Sealevel sensor...
johnamjr's Avatar
Views 514 Comments 0 johnamjr is offline
Old
Progress updates
Posted 08-20-2013 at 08:12 PM by johnamjr
All windows cleaned and hardware sandblasted. New rubber seals on every window, hatch and door. Plumbing vents got new rubber. New Led tail lights installed and working. Working on roof vents and fans. New Led marker lights almost done.( will post new pics when finished) My wife has her eyes set on the curtains and new upholstery fabric. We have new axles on order from Colin Hyde. I placed a POR 15 order.
johnamjr's Avatar
Views 756 Comments 0 johnamjr is offline
Old
More Pics
Posted 08-20-2013 at 08:03 PM by johnamjr
Not the best Pics but Here is what we started with.
ID:	3862   Click image for larger version
ID:	3864   Click image for larger version
ID:	3866   Click image for larger version
ID:	3868   Click image for larger version
johnamjr's Avatar
Posted in Uncategorized
Views 714 Comments 1 johnamjr is offline
Old
Our New Airstream
Posted 07-22-2013 at 07:53 PM by johnamjr
On July 11th we purchased our first AS a 1970 25' tradewind. It had been sitting for a while but over all in good shape. Need some updating as everything is original. It had \some leaks not too bad. Went over the entire outside and resealed everything with tempro 626 and Arcyl-r. While my wife has been tackling the windows and seals one at a time. Once we get it all sealed up it will be time for all new running gear to pass state inspection.
ID:	3854   Click image for larger version
ID:	3856   Click image for larger version
johnamjr's Avatar
Views 715 Comments 3 johnamjr is offline
