Old
starting the banquette
Posted 03-01-2016 at 03:53 PM by nskinner
Before building out the shower stall I have decided to upgrade the supply lines to the bathroom and kitchen while I can. They all passed inspection but upgrading now seems the best option. I'm part way through that process using 1/2" PEX but we are still having mostly sub zero highs here which makes plumbing a challenge. So until it warms up a bit I'll be working at the front end of the trailer.
Here our plan is to replace the nasty old Gaucho with a horseshoe banquette and a telescoping...
Name:	banquette layout.jpg
ID:	4394   Click image for larger version
Name:	banquette framing.jpg
Views 861 Comments 1 nskinner is offline
Old
Starting the re-model
Posted 03-01-2016 at 03:13 PM by nskinner
By the time the painting was done the summer was ending and I moved the trailer into a barn for storage over winter. The following summer (2014) saw me just too busy for the long drive to work on the trailer, I got up there once or twice and did a few small repairs, but by the fall it was pretty clear that I needed a new location to do this work. So this past summer, after a couple of false starts we finally got a great spot that is about 5 mins from home and that I can actually see from my work....
Name:	vinyl siding brackets.jpg
ID:	4390   Click image for larger version
Name:	partition template.jpg
Name:	%22draft%22 pocket door.jpg
ID:	4392   Click image for larger version
Views 744 Comments 0 nskinner is offline
Old
Prep and paint...
Posted 03-01-2016 at 02:34 PM by nskinner
Once the leaks (or most of them) were addressed, I researched the forum for the best advice on surface prep and painting. I can't say enough about how helpful the community was in this area, it certainly seems like many people have made mistakes here that I was very grateful to learn about and avoid!
I scrubbed every surface twice with Spray Nine and then again with TSP before sanding everything. I did 2 coats of Kilz primer using a sprayer, which was super quick, but I realized, better...
Name:	all gutted.jpg
ID:	4388   Click image for larger version
Name:	interior spraying.jpg
Views 839 Comments 0 nskinner is offline
Old
The initial gut...
Posted 03-01-2016 at 02:22 PM by nskinner
Once we had our trailer in place, I spent the summer driving the 90 mins back and forth to our friends farm. Not the most ideal situation to get so much work done, but it was our best option at the time, and I got to spend a good amount of time in beautiful Walkworth Ontario.
Initially I had thought I would remove all the cabinetry but leave shower / tub etc, but as the gut progressed it became evident that this stuff should go too.
As expected, once stripped down a few hidden issues...
ID:	4384   Click image for larger version
Name:	leak repair.jpg
Name:	rear floor out.jpg
ID:	4386   Click image for larger version
Name:	rear floor repair.jpg
Views 644 Comments 0 nskinner is offline
Old
1979 Sovereign 31' "Seasmoke" Re-model
Posted 03-01-2016 at 12:30 PM by nskinner
Updated 03-13-2016 at 08:57 AM by nskinner
After a couple of years of bursts of progress followed by unforeseen delays, we are hopefully finally settled in to get this job done!
We picked up our 1979 31' Sovereign in 2013 from CanAm RV in London, ON. We were looking for an AS of this size and vintage with an exterior and mechanics in good condition and an interior ready to be re-modelled. The good folks at CanAm looked after us well, and we got exactly what we were looking for. The shell was in excellent condition, all the electrical,...
Name:	original interior.jpg
ID:	4380   Click image for larger version
Views 720 Comments 1 nskinner is offline
