Posted 04-14-2024 at 04:01 AM by cesalie2
Originally Posted by cesalie2
Started investigating a small coolant puddle under the radiator.
Whipped out the radiator pressure tester, pumped the pressure up to 11 psi and …coolant began leaking out near the passenger side lower radiator tank.
Attempted to see if it was leaking further up the radiator. Visibility is limited.
Will have to find the time to disassemble the radiator metal cage and identify the culprit.
In the event the radiator is leaking, old school
"Alumi-holic"
Views 106
Comments 0
