Go Back   Airstream Forums > Blogs
Old
Stablizer removal... a few rusty screws and gritting teeth
Posted Yesterday at 07:10 PM by hessehesse
Removing the stabilizers was tough..the screws were rusts. Took quite a bit of teeth gritting to get them off....
ID:	1124  Click image for larger version
Posted in Uncategorized
Views 34 Comments 0 hessehesse is offline
Old
Going Back Under to Belly to Last Big Pan
Posted Yesterday at 07:05 PM by hessehesse
To get some fresh air, I decided to go back under and get the last belly pan. First, let's geek out and take a look at all of these corroding rivets...woo hoo! Some of them had washers on them...was that original? ...hmmm...wonder what's underneath...can't wait to see!
ID:	1120  Click image for larger version
Views 32 Comments 0 hessehesse is offline
Old
How do you get the door frame thing off to get to the rivets???!!
Posted Yesterday at 06:56 PM by hessehesse
Okay - I can't figure this one out. The panels go behind the metal door "frame" that looks like it should pop out. I show here where I cut around the door (yes, I was frustrated!) because the rivets for the panel are behind that frame. The other picture (not that great) shows the smaller rivets that I eventually took out - still no luck. Ideas?
ID:	1118  Click image for larger version
Views 30 Comments 1 hessehesse is offline
Old
Then came the panels working down from the sides...
Posted Yesterday at 06:51 PM by hessehesse
It's all down hill from here...(famous last words)... pretty quick to remove. Luckily I didn't find any leaks, wet spots, or mold...
ID:	1114  Click image for larger version
ID:	1116  Click image for larger version
Views 28 Comments 0 hessehesse is offline
Old
Layers lead me to the top layer...for removal
Posted Yesterday at 06:48 PM by hessehesse
So, with all of these layers - the 1 foot overlap required me to go to the top layer first and remove from there. This is no whimpy vinyl clad aluminum. It was very stiff!
ID:	1112  Click image for larger version
Views 26 Comments 0 hessehesse is offline
Old
Rainy day made it look shiny!
Posted 10-30-2009 at 10:22 AM by hessehesse
This rainy day picture of "the shop" made the streamer look shiny! Okay...not exactly like some of your fix it jobs out there - but at least I have a glimpse of what it might be at some point in the future!
Views 294 Comments 2 hessehesse is offline
Old
Layers and layers and layers of panels...agh...
Posted 10-30-2009 at 10:18 AM by hessehesse
Updated 10-30-2009 at 10:19 AM by hessehesse (dup photo)
I'm not sure how others just removed the bottom panels. Mine seem to be layered/overlapped with the top panels by at least a foot (kind of a waste!). And then those are underneath the top/ceiling panels. I can kind of bend them - but can't get to the rivets behind them...So I'm going with the real complete gut and removing all - including the ceiling. And now I've been inspired by some pretty cool renovations I've seen on-line...! Here are some panel pics for your enjoyment - though they probably...
ID:	1076  Click image for larger version
Views 280 Comments 2 hessehesse is offline
Old
Getting closer to the bones! Kitchen and front gutted.
Posted 10-30-2009 at 10:13 AM by hessehesse
Well - I'm finally getting closer to the bones of this beast. In these pictures you can see the kitchen is gutted - and a picture of the old heater that was disconnected awhile ago. Not sure if it works - or ever worked - but some more critters made good use of it's interior! I unscrewed the vent from the outside and with the gap started leaking water on the interior - highlighting the importance of those seems! ...here's my dog Cinque ("Chinkway") who didn't want to hang outside during...
ID:	1071  Click image for larger version
ID:	1073  Click image for larger version
Views 238 Comments 0 hessehesse is offline
Old
Drilling out rivets... simple with a few annoyances
Posted 10-22-2009 at 11:25 AM by hessehesse
So, drilling out rivets is actually really simple. What I've learned is that its easier to just let the drill to the work versus pushing hard thinking you need to "get that rivet". Let the drill to the work. Once in a while the rivet will spin (i.e. it's loose) and you simply have to angle the drill to catch an edge of the rivet.
One annoying thing is that the tops of the rivets end up collecting on the drill bit (anyone have any ideas on this?). See left picture. To...
ID:	1061  Click image for larger version
Views 518 Comments 5 hessehesse is offline
Old
And behind the refrigerator are Aliens!!!
Posted 10-20-2009 at 03:18 PM by hessehesse
Did anyone see Alien/Aliens? These wasp cocoons were behind the refrigerator and scared the Dickens (or some other author) out of me! I tested one to see if one of those head snappers would pop out... luckily they had migrated to someone else's mother ship already.
And of course, there was the token left overs from years of mouse and rat parties under the refrigerator (I think this is where the teenagers
hung out).
ID:	1057  Click image for larger version
ID:	1059  Click image for larger version
Views 329 Comments 0 hessehesse is offline
Old
Next Up: Removing panels between bedroom and kitchen
Posted 10-20-2009 at 03:11 PM by hessehesse
Here are some pics before removing the panels between the bedroom and kitchen and after. Notice that the kitchen shelves were suspended on this panel - but that everything else held up by itself (someone had asked about this). Also the overhead bins are supported by the panel - but could be supported by other means if you wanted a "more open feel".
ID:	1053  Click image for larger version
ID:	1055  Click image for larger version
Views 271 Comments 0 hessehesse is offline
Old
Documenting the plumbing for removal
Posted 10-20-2009 at 03:05 PM by hessehesse
I was careful to document how the plumbing was done in order to reinstall. However, about now I have fessed up to the nagging Gremlin on my shoulder and am going for the complete gut!
The stink from the mouse and pack rat smell hasn't gone away since the rugs were removed. It is just soaked into the wood. Sanding would probably only be a surficial treatment - and some of the wood is rotten anyway...
Here's the gutted and documentation pics...1) water hosing and pressure...
ID:	1049  Click image for larger version
ID:	1051  Click image for larger version
Views 274 Comments 0 hessehesse is offline
Old
Here's the bathroom coming apart...
Posted 10-20-2009 at 02:59 PM by hessehesse
So back to the grind of getting to the floorboards. The bathroom had to come out as reluctant as I was to go here... meanwhile, there was a little nagging gremlin tapping me on the shoulder ("Come on...just gut the thing! You know that's where you are headed.").
The plastic strips cracked on removal... the key to getting it out was behind these strips. You don't have to remove the "rear ceiling cap" to get everything out luckily. This thing was fragile and...
ID:	1045  Click image for larger version
ID:	1047  Click image for larger version
Views 245 Comments 0 hessehesse is offline
Old
Floorboard replacement without removing C channel and frame? Help/feedback please...
Posted 10-11-2009 at 07:33 PM by hessehesse
Okay, so I'm at a point and am understanding better what I am up against. I need some feedback on my floorboard issue. I didn't realize that the C channel is attached to the whole frame of the airstream - such that to get to the floor boards, you have to pull up the entire shell...! I saw this in a few other posts but didn't know that this was a must. So, here are my thoughts on what I can (given my limited resources, tools, money, space etc) do:
1) Cut the floorboards about 3 inches...
Views 584 Comments 6 hessehesse is offline
Old
Interior Panel and Wall Removal: Slippery Slope Defined!!
Posted 10-09-2009 at 11:03 PM by hessehesse
So in this quick blog, here is where the slippery slope begins. Remember, I was "just" trying to get to the floor boards! I probably could have read some blog somewhere... but I can be pig headed too!
Anyway, in these pictures, you can see how these panels totally overlap. I have to remove these panels to eventually get to the floorboard. These panels cover the C channel which is above the floorboard.
The Catch: The bathroom panels rest BEHIND the bedroom...
ID:	1034  Click image for larger version
Views 437 Comments 1 hessehesse is offline
