Go Back   Airstream Forums > Blogs
Old
What the heck kind of blog is this !!!!
Posted 10-14-2009 at 04:34 PM by stain
Well I have not done an entry in awhile !!! SO ... What is new !!! holiday In august so not much done that month ... I used 3/4plywood for my floor marine spar vanished and bolted down with elevator bolts..a little tricky to get the ply under the channel but I managed .. then I took off all the interior skins ... and pulled the remain insulation out of the walls and roof yuk...Clean the walls and roof and looked for water stains on the inside of panels... This helped me to find the leaks ... most...
stain's Avatar
Views 218 Comments 0 stain is offline
Old
oh ya dont forget the pic s
Posted 10-14-2009 at 02:09 AM by stain
I lost my camera in august so I have used my phone !! still looking for the camera.... I gotta get this posting pictures thing down !!!!
ID:	1038  Click image for larger version
ID:	1040  Click image for larger version
stain's Avatar
Views 131 Comments 0 stain is offline
Old
Wells and pan down...
Posted 06-28-2009 at 01:31 AM by stain
Today I got the center belly pan drop and the wheel wells out .. I am going to be able to reuse the front pan only as the back was badly patched up ,all of the sides will also have to be redone due to the outriggers poking through .. no more walking on iron I was beginning to feel like an iron worker ... drilled out some rivets today... The wells will have to be touched up... .. stain...
stain's Avatar
Views 211 Comments 1 stain is offline
Old
frame
Posted 06-26-2009 at 12:53 AM by stain
Well I found my camera today.. so I have a few pictures to post... I have taken off all the lower skins so I had to wired her back up today and now I have lights again.. I have been to busy at work to get much done this week ...
ID:	751  Click image for larger version
Name:	painted frame ...jpg
stain's Avatar
Views 197 Comments 1 stain is offline
Old
59 Overlander .. ...
Posted 06-23-2009 at 07:23 AM by stain
Well I should be installing the sheeting for the floor this week.. I have done two coats of spar varnish and will be apply the third coat after they are installed...I will be using 3/4 inch plywood on top of bubble foil insulation..I will be leaving the back sheet off for any plumbing that needs to be installed. after removing all the delaminated plywood the trailer smells a lot better ...I have also removed the bottom row of panels and insulation.. I am going to restore her as close to vintage...
stain's Avatar
Views 199 Comments 1 stain is offline
Old
Posted 06-20-2009 at 03:04 PM by stain
I am going to start a blog for the restoration of my Overlander ... This will help me to keep a time line on me project .... Tare out is done ... floor has been removed ..frame is 75% ground and repainted ... the frame is in great shape for being 50 years old, wow... back to work.. I need to find out about using bubble insulation under subfloor ... also need to get tanks and figure out layout.... new belly pan... too much work not enuff time...
stain's Avatar
Views 157 Comments 0 stain is offline
