Go Back   Airstream Forums > Blogs
Join us as we rebuild our 1962 22" Flying Cloud in preparation for our cross-country tour.
Old
Custom Aluminum Replacement Roof Vent for Our 62 Flying Cloud
Posted 02-24-2009 at 07:32 PM by FLYNCLD (1962 Flying Cloud Eco-Friendly Reconstruction)
We just finished installing a new custom made roof vent to replace the original fiberglass vent which was in very poor shape. We were not able to find anything that looked close to the original, and look way cool as well, so we fabricated this one. As there were several holes in the roof where the PO's had moved vents around at one time or another, we made the base plate large enough to cover all the various holes that had been cut in the roof over the years. Many hours and many rivets later the...
Name:	Exterior Skin Repairs 004.jpg
ID:	429  Click image for larger version
Name:	New Vent 017.jpg
Name:	New Vent 021.jpg
ID:	431  Click image for larger version
Name:	New Vent 023.jpg
Name:	New Vent 025.jpg
Tags: roof vent
FLYNCLD's Avatar
Posted in Uncategorized
Views 819 Comments 6 FLYNCLD is offline
Old
Window corrosion removal and polish
Posted 02-24-2009 at 07:15 PM by FLYNCLD (1962 Flying Cloud Eco-Friendly Reconstruction)
As we move forward on the exterior, we have developed a pretty easy system for removing corrosion from the window frames and polishing them back up.
As you can see in the photos, we begin by removing the heaviest surface corrosion with a small wire brush.
We then use a foam sanding block to get down into any tight corners the brush may have missed.
Next we use ScotchBrite to smooth out the scratches left by the first two steps. We use the ScotchBrite...
Name:	Window Cleaning 001.jpg
ID:	421  Click image for larger version
Name:	Window Cleaning 003.jpg
Name:	Window Cleaning 005.jpg
ID:	423  Click image for larger version
Name:	Window Cleaning 007.jpg
Name:	Window Cleaning 008.jpg
ID:	425  Click image for larger version
Name:	Window Cleaning 010.jpg
Name:	Window Frames.jpg
ID:	427  Click image for larger version
Name:	Window Cleaning 002.jpg
FLYNCLD's Avatar
Posted in Exterior Work
Views 414 Comments 0 FLYNCLD is offline
Old
To Blog or Not to Blog...That is the Question!
Posted 01-22-2009 at 07:54 PM by FLYNCLD (1962 Flying Cloud Eco-Friendly Reconstruction)
There seems to be a bit of confusion about the difference between blogs and forums. If you have a question, need advice, are looking for something, etc. please refer to the FORUM section of this site. You will then be able to find a topic that best matches your subject and post to the appropriate section.
If you are doing a major restoration, posting your road trip, or other types of things that will be an ongoing project, then a blog is the proper place to do this.
FLYNCLD's Avatar
Views 436 Comments 3 FLYNCLD is offline
Old
Gray Tank Installation Update!
Posted 01-19-2009 at 01:48 PM by FLYNCLD (1962 Flying Cloud Eco-Friendly Reconstruction)
We have completed the gray water tank installation in our 1962 Flying Cloud including rust prevention, tank brackets and belly skin repairs. Everything works like a charm! After we finish up a few more repairs underneath, it's on to the electrical and the interior!
Name:	Belly Skin Replacement 009.jpg
ID:	177  Click image for larger version
Name:	Belly Skin Replacement 010.jpg
Name:	Belly Skin Replacement 012.jpg
ID:	179  Click image for larger version
Name:	Gray Tank Installed 006.jpg
Name:	Gray Tank Installed 007.jpg
ID:	181  Click image for larger version
Name:	Gray Tank Installed 008.jpg
Name:	Gray Tank Installed 009.jpg
FLYNCLD's Avatar
Views 925 Comments 6 FLYNCLD is offline
Old
1962 Flying Cloud Gray Tank Installation
Posted 01-02-2009 at 01:22 PM by FLYNCLD (1962 Flying Cloud Eco-Friendly Reconstruction)
After we finished gutting the interior, the first major project we are undertaking is the installation of a gray water tank. Our trailer was not originally equipped with one, and they are now mandatory in many parks etc.
As we are installing a composting toilet which does not require a black tank, we began by removing the original black tank which was located under the existing toilet in a raised portion of the rear floor. This will allow us to install the new toilet at floor...
Name:	Gray Tank Installed.jpg
ID:	155  Click image for larger version
Name:	Gray Tank Installed 001.jpg
Name:	Gray Tank Installed 003.jpg
ID:	157  Click image for larger version
Name:	Gray Water Tank Installation 001.jpg
Name:	Gray Water Tank Installation 002.jpg
FLYNCLD's Avatar
Views 1305 Comments 4 FLYNCLD is offline
Old
1962 Flying Cloud "Eco-Friendly" Reconstruction
Posted 01-01-2009 at 11:11 PM by FLYNCLD (1962 Flying Cloud Eco-Friendly Reconstruction)
Welcome to our blog. My wife and I are in the process of reconstructing a 1962 Flying Cloud in preparation for an extended trip around the country. We are using as many "eco-friendly" materials and systems as possible. This includes a complete solar system, composting toilet, and a variety of sustainable materials in the construction.
As we tour the country, we will be visiting eco-friendly and sustainable businesses, intentional communities and projects, as well as just...
Name:	Flying Cloud-Arrival 001.jpg
ID:	142  Click image for larger version
Name:	Flying Cloud-Arrival 002.jpg
Name:	Flying Cloud-Arrival 003.jpg
ID:	144  Click image for larger version
Name:	Flying Cloud-Arrival 004.jpg
Name:	Stripped Interior 001.jpg
ID:	151  Click image for larger version
Name:	Stripped Interior 002.jpg
Name:	Stripped Interior 003.jpg
ID:	153  Click image for larger version
Name:	Stripped Interior 004.jpg
FLYNCLD's Avatar
Views 727 Comments 6 FLYNCLD is offline
