Old
'73 TW, 25 foot issues!!
Posted 06-29-2012 at 06:51 AM by bmwsid
Originally Posted by TG Twinkie View Post
We always shut the pump off when not in use. At first it was a bit of an inconvenience because the switch is located in the galley. I installed a switch in the bathroom. So the procedure is turn on the pump, turn on the lights (if needed) , do your business, turn of the pump and lights. No water wasted.
How did you run the wires for the pump to the other end of the AS?
TIG welder
Posted in Uncategorized
Views 672 Comments 0 bmwsid is offline
Old
Posted 06-29-2012 at 06:47 AM by bmwsid
Originally Posted by wahoonc View Post
You won't find much in the same size range that tows better than an Airstream. I tow 31' with an F150. Also hard to beat that aluminum shell for durability. I have had a couple of SOB's over the years and wouldn't trade my old Airstream for a new anything.
Aaron
Is SOB a "square something?"
How did you run the wires to the pump to the other end of the AS?
TIG welder
Views 626 Comments 0 bmwsid is offline
Old
Posted 06-28-2012 at 06:25 PM by bmwsid
Give your wife a list of all the crap that you have to try and get fixed under warranty on a new unit, and how it will have to sit at the dealer for months, or you will have to tow it to Ohio to have the stuff fixed (again) at the factory.
My personal preference is to dance with the devil you know...
Aaron
Think it would be cheaper to have it done in Ohio??
TIG welder
Views 682 Comments 1 bmwsid is offline
