Old
Armstrong RV Air conditioners
Posted 09-24-2017 at 03:02 PM by Scoutx
[QUOTE=Scoutx;2010387]Note A.O. Smith has been bought out the new designation for this motor is the RAL1006.
Note this motor spins CCW from the end of the motor where the leads go into the case. I accidently mounted mine upside down since the extra of the case bolts stuck out the other side making it perfect for mounting to the base plate. So I would suggest that you either:
1) reverse the direction of the case bolts one at a time
2) remove the whole rotor assembly...
Posted in Uncategorized
Views 297 Comments 0 Scoutx is offline
