Old
Twin 6 Volt battery install & charger/converter upgrade
Posted 04-18-2019 at 07:44 PM by GMFL
Upgraded my batteries from (2) Group 27 12 volts to 2 Trojan T105 6 volts. This swap was mandated by waking up one morning at Stone Mtn GA campground to the smell of sulfur/rotten eggs, yep I officially cooked on of my factory interstate batteries. The water level was check religiously so I am going to blame the factory single stage charger. Before I installed the new Trojans I installed a new Progressive Dynamic 4655v charger converter. This unit is a 4 stage charger that monitors your batteries...
ID:	4586   Click image for larger version
ID:	4588   Click image for larger version
ID:	4590   Click image for larger version
ID:	4592   Click image for larger version
ID:	4594   Click image for larger version
GMFL's Avatar
Overkill Specialist
Posted in Uncategorized
Views 130 Comments 0 GMFL is offline
Old
Airstream Service Network
Posted 04-13-2019 at 06:27 PM by GMFL
Updated 04-14-2019 at 07:48 AM by GMFL
I posted this in a thread earlier, but thought it would be good to add as a Blog post.
Getting service work done on your Airstream if you are either (A) not able to do the work, (B) donít have the time to do the work, or (C) donít need to personally do the work because itís a warranty issue can be very challenging.
Returning back to the factory (The Pilgrimage to the Mothership) is often been stated to be the best place to take your Airstream trailer...
GMFL's Avatar
Overkill Specialist
Views 90 Comments 0 GMFL is offline
Old
On the Road repair
Posted 03-10-2019 at 08:26 PM by GMFL
Updated 03-16-2019 at 04:31 PM by GMFL
We are currently in Gatlinburg TN spending some time on the Redneck Riviera. While making the 6 hour drive up our panty door decide it wanted to remove itself from the cabinet. Well almost anyway. The 2 screws holding the bottom hinge base plate ripped out of the cabinet wall and 1 of the screws from the upper plate also was stripped. This left the cabinet door hanging precariously by 1 little screw. I was 1 screw away from uncertain damage to either the cabinet door, flooring, or both. I am...
ID:	4895   Click image for larger version
ID:	4897   Click image for larger version
GMFL's Avatar
Overkill Specialist
Views 216 Comments 0 GMFL is offline
Old
Marker/Clearance light Replacement
Posted 03-02-2019 at 07:15 AM by GMFL
Updated 03-30-2019 at 07:32 PM by GMFL
Iíve got a couple of Clearance lights that are on the fritz, one is out and the other is intermittent. So in Grand ďDept of OverKillĒ style Iím going to replace them all with a few upgrades along the way. Iíve ordered the Replacements (7 Red and 4 Amber) from ďThe Trailer ShopĒ an eBay store for $165.15. Amazon also had them but they were $208.12 there. The old lights where starting to get cloudy anyway. See pics...
UPDATE.....New lights arrived yesterday. We will be traveling in...
ID:	4893   Click image for larger version
ID:	4901   Click image for larger version
ID:	4903   Click image for larger version
ID:	4906   Click image for larger version
ID:	4908   Click image for larger version
GMFL's Avatar
Overkill Specialist
Views 292 Comments 2 GMFL is offline
Old
Maxim Skylight
Posted 01-15-2019 at 07:50 PM by GMFL
Updated 03-16-2019 at 05:12 PM by GMFL
Just some quick photos of my Maxim Skylight install.
Maxim is a great company to work with and they provide an excellent product. It is very simple to order your new skylight by simply providing Maxim with the measurements of your skylight opening and adding 1/4” to each measurement to allow the new skylight to slide down over the existing roof curb.
http://maximskylights.com/airstream-skylights/
ID:	4887   Click image for larger version
GMFL's Avatar
Overkill Specialist
Views 425 Comments 2 GMFL is offline
