1. Old Comment
    GMFL's Avatar
    2014 23D International Fresh Water Tank Replacement
    Paige,
    Thank you for your kind words. Please feel free to reach out anytime if you have a question.
    Thanks again,
    Ronnie
    Posted Yesterday at 05:18 PM by GMFL GMFL is online now
  2. Old Comment
    GMFL's Avatar
    15K AC upgrade and proper AC drip cup install done
    The drip tube does enter through the gasket. One tube off each cup then connect to a tee fitting and drain out the main drain tube inside the trailer wall.
    Posted Yesterday at 05:15 PM by GMFL GMFL is online now
  3. Old Comment
    harryk's Avatar
    OK, I am finally beginning to understand what the cups are for....but I have to ask, does the drip tube have to go thru the gasket to get inside the rv to then connect to the main down the wall drip tube ? Originally I thought the cups were on the interior part of the ac. On the old system wasn't there a drip pan inside accessible from the interior ?
    Posted Yesterday at 01:51 PM by harryk harryk is offline
  4. Old Comment
    GMFL,
    I cannot thank you enough for documenting and posting your photos and process for this project here and at your other post regarding this project. What is going on behind the tank pans has been a relative mystery to me, and you have shed so much light on it. Thank you!
    I really want to ditch my plastic drain valve (I have to us a lever to get it to open and it feels like the handle could snap at any time) You've helped me understand what this would entail. Again, Thank you!
    Also, the quick connect for the line drain is a great idea. If I ever get into this project, I'd like to do the same thing.
    -Paige
    Posted 03-17-2019 at 02:16 PM by Papatango Papatango is offline
  5. Old Comment
    GMFL's Avatar
    Custom 3 lift kit
    Welcome! Thanks for the kind words.
    Posted 02-26-2019 at 05:08 PM by GMFL GMFL is online now
  6. Old Comment
    GMFL's Avatar
    Hitch Holder
    Yes. It locks in place with the same pin used in the truck. In other words there is a pin hole through the receiver/holder.
  7. Old Comment
    Hitch Holder
    Can you lock the hitch?
    Posted 02-26-2019 at 11:25 AM by Projet2907 Projet2907 is offline
  8. Old Comment
    Custom 3 lift kit
    This is excellent. Thank you!
    Posted 02-25-2019 at 10:42 AM by kb7our kb7our is offline
  9. Old Comment
    GMFL's Avatar
    Countertop plug swapped and boxed
    Dermal with a roto-cutter bit and a very steady hand.
    Posted 02-23-2019 at 06:10 PM by GMFL GMFL is online now
  10. Old Comment
    aswell's Avatar
    Very nice. Curious, what tool did you use to expand the opening?
    Posted 02-23-2019 at 10:31 AM by aswell aswell is offline
  11. Old Comment
    GMFL's Avatar
    Maxim Skylight
    Mine original one was stuck on with double sided tape and was in ok shape. I replaced it to head off any problems. The Maxim skylights are AWESOME! 3 lenses tinted to your preference increase the insulation rating of the skylight.
    Posted 01-25-2019 at 03:28 PM by GMFL GMFL is online now
  12. Old Comment
    tjdonahoe's Avatar
    Maxim Skylight
    Good job..my 13 uses double sided tape and they are still good
    Posted 01-22-2019 at 08:20 AM by tjdonahoe tjdonahoe is offline
  13. Old Comment
    eganwh's Avatar
    Replaced all the plugs and put the new ones in junction boxes
    Thanks for the link. I was thinking of adding an outlet - this box will work great.
    Posted 12-18-2018 at 08:30 PM by eganwh eganwh is offline
  14. Old Comment
    Posted 12-18-2018 at 08:02 PM by GMFL GMFL is online now
  15. Old Comment
    eganwh's Avatar
    Looks good. Rivets to hold the box in place. Great idea - low profile so minimal interference with the cover plate.
    Are the blue outlet boxes standard residential size?
    Keep up the good work!
    Posted 12-17-2018 at 09:40 PM by eganwh eganwh is offline
  16. Old Comment
    GMFL's Avatar
    Airstream Pole Barn #2
    It’s nice to be able to wash it under the cover. Also post spacing allows for all the awnings to be opened to dry. I could enclose it but I think it would be pretty confined in there if I did.
    Posted 12-04-2018 at 06:48 PM by GMFL GMFL is online now
  17. Old Comment
    That's pretty slick, but why not enclose it?
    Posted 12-02-2018 at 11:42 PM by coasttocoast coasttocoast is offline
  18. Old Comment
    GMFL's Avatar
    Thanks for the kind words. I’m working on posting detailed write ups on all my mods.
    Posted 12-02-2018 at 08:31 PM by GMFL GMFL is online now
  19. Old Comment
    Boxite's Avatar
    THIS is the type of posting I really appreciate. THANK YOU. Excellent job!
    Posted 12-02-2018 at 07:48 AM by Boxite Boxite is offline
  20. Old Comment
    More photos of my 6 volt Trojan T105 battery install
    sweet... I just got my trojans last week and am looking forward to put'n them in the new battery box retrofit... should make dry camping much more fun and less worrysome.
    why airstream didn't go to these years ago is still a question unanswered... when ask at a meeting.. they did the shuffle off stage left...
    Some came up with pretty lame excuses as to why but the oldies said that when the gp 24s were around they were about 25 bux each... cheep... and so who cared if they only lasted a year... you put new ones in seasonally... accroding to them.. but now that they are approching 100 bux each... makes a big difference in yearly cost...
    So most ventured off into better battery that required a better location.
    While mounting them on the A frame is not the best spot.. it was simple and effective to do the job according to the oldies again...
    Strange that A/S fought it for a while and then started making the tool box into a battery box... interesting...
    Posted 12-02-2018 at 01:04 AM by GM Airstream GM Airstream is offline
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
